Results 1 to 10 of 13
- Jul 2005
- 61
October 4th, 2005 09:22 AM #1At about 60-80kph, when it is about to shift to fourth gear, the gears slip and the rpm just revs at hindi na nag-shift.
what should i do with this?
a mechanic told me that it is stuck to third gear na.........how about your opinion guys?
he's talking about........kung kaya daw dukutin yung sa automatic yun muna bago replace tranny. i don't get what he was saying. BTW my car is galant ss at.
- Jan 2005
- 22
October 4th, 2005 09:37 AM #2Check your AT fluid level and quality.
Baka makuha ng bagong AT fluid. Otherwise, major repair/replacement work.
- Jul 2005
- 61
October 4th, 2005 10:03 AM #3just replaced my atf about two months ago.
pero shempre drain lang and hindi napalitan lahat because of those stuck in the torque converter.
- Jun 2004
- 1,311
- Jul 2005
- 61
October 4th, 2005 08:56 PM #6
Walang sira yung transmission mo, wag kang magpapalet... ang sira ng auto mo eh yung Transmission O/D solenoid valve. Try mo to, turn off engine, then turn on accessory switch sa key tapos press mo yung Overdrive, dapat may maririnig kang clicking noise if you turn it on or off somewhere sa transmission... pag wala hanapin mo yun kasi pag walang kuryente hindi talaga mag shi-shift sa higher gears ang auto mo....
- Jul 2005
- 61
October 5th, 2005 09:39 AM #8thanks sir..........gagawin ko yan.
thanks talaga. namomroblema na nga ako saan hahanap ng funds for that tranny replacement.
sir in fixing this kailangan pa din bang ibaba yung transmission?
- Jul 2005
- 61
October 6th, 2005 09:05 AM #9i have tried it na po.
all the clicking i hear is the switch itself and none on the tranny area.
then i think i should have this replaced. is it inside the tranny?
mga how much kaya aabutin?
October 8th, 2005 06:04 PM #10
nasa labas lang yun ng transmission, hindi kailangan ibaba and transmission mo, usually may single wire lang yun, kasi yung negative eh naka attached na sa body ng auto mo. check mo rin lahat ng fuse mo baka naman putol.
yung solenoid valve ang nag-cocontrol yun ng transmission oil pressure para mag shift. Kaya pag tinangal mo yun, kailangan saluhin mo yung transmission oil or be ready for replacement oil just incase. Maghanap ka ng wire na papunta sa transmission then bilangin mo kung ilan lahat. then hanapin mo yung single wire na may connector socket na male and female (kasi natatangal talaga yun incase 4 repairs). pag nakita mo... ang itsura ng solenoid valve ay mukhang cylinder lang at estimated size ay mga 3 x 5 inches lang. Pero kung may kakilala kang mechanic, ask mo kung ano yung solenoid valve ng auto trans. or kung gusto mo, pa-estimate ka lang kunwari then tanong mo sa mechanico kung saan yung solenoid sa tranny mo...
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
