Results 1 to 10 of 22
April 17th, 2004 06:48 PM #1
Napansin ko kagabi na masyado nang mausok buga ng tambusto ng kotse ko(corolla xe 92), I had my change oil last feb.. so i decided to have it again this morning, but after my change oil, paknsyet!!!.. parang walang nagbago.. mausok pa rin!!!.... ano kaya nangyari sa tsikot ko mga pre...papa-overhaul ko na ba?.. help naman pips... thanks a lot!!!!
- Nov 2002
- 50
April 17th, 2004 07:42 PM #2kung puti ang usok, sad to say baka due for top overhaul ka na... baka sumusunog na ng oil ang engine mo, palitin na ang piston rings...
- Mar 2003
- 82
April 18th, 2004 07:08 AM #3Malakas na ba kumain ng langis? baka worn out na valve seals mo. Pag ganon due ka na for top overhaul. sana yun lang ang sira. pacheck mo na kaagad sa suking mekaniko.
April 18th, 2004 10:51 AM #4
San po ba pwede maganda pa-check up to?.. Yung mekaniko ko kasi sa cavite pa. Since dito na ako nakatira sa Camp Aguinaldo, yung malapit na sana.. may marerecommend po ba kayo?.. how much po ba for top overhaul?..
April 18th, 2004 11:03 AM #5
average costs ng labor nyan is 5,000. Excluding the parts and items you will buy pa. For sure pre you have to have your car overhauled na. Yun Piston rings mo maluwag na sobra so oil is being burned below the cyl head. If you let this go on, your Valve tuppets will become dirty and have residue build up w/c will cause lost in compression or worst katok na makina. You can chk this pa by opening your OIL CAP, if smoke is coming out there, then for sure you have to open it... Good Luck!
April 18th, 2004 11:12 AM #6
5 tau, wow.. tight budget pa naman, san po ba pwede ipagawa to? yung pwede pagkatiwalaan...
- Nov 2002
- 29
April 18th, 2004 10:44 PM #8
well if i am you, i'll ask my friends around. Dapat yun mech malapit lang place sa iyo so he could do it sa house mo na lang and kakilala para la masyado problem. If papasok mo lang kse sa talyer for sure naka linya yan sa job orders den bka d ka pa makapili ng pyesa na ikakabit. Madami naman magaling na siraniko, i mean mekaniko around. Ok yun if recomended ng kakilala mo.
April 19th, 2004 10:22 PM #9
174,000 na km reading nito, i bought it from a friend last Aug, 166K pa siya noon. May pasok din ako from mon to sat, so wala talaga ako time for that. Anyway guys, thanks.. medyo hindi na mausok ngayon after change oil, but still, kinakabahan ako, hindi siya dati ganito eh.. konti na lang yung usok, im not sure if its normal, pero.. hindi siya ganon kausok before
Monk-owned R53
