Results 21 to 23 of 23
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 27th, 2008 09:50 AM #21when you replace the boot you can inspect the bearings naman. just have it looked at by whoever will fix it for you.
January 28th, 2008 10:02 PM #22
zach, bro, ano pinagawa mo and ano ang results?. . .pareho tayo ng kaso. . .kapapalit ko lang din ng shocks sa unahan last friday, then kanina, narinig ko yung "tok" sound kapag nag-a-accelerate from stand still. . .wala naman dati yun. . .pinatingnan ko na rin yung lower ball joints and rubber bushings when they replaced the shocks and sabi e okay pa naman daw. . .isa pang symptom e kumamabig na sya sa kaliwa ngayon. . .before the shocks were replaced, sa kanan sya kumakabig (kahit yung shocks sa kaliwa ang damaged back then. . .me kinalaman ba yun?). . .
inputs naman mga bro. . .salamat!
- Jan 2008
- 42
January 29th, 2008 08:31 AM #23
high idle RPM at engine start
