Results 1 to 5 of 5
January 4th, 2007 09:42 AM #1
Mga Sirs, Good Morning and Happy New Year!!!!
Need help lang po with my L200 (model 1997), regarding sa glow plug nya, it took me 3 to 4 times mag heater before i can start the engine, nakikita ko po kse sa ibang L200 one click lang sa kanila umaandar na, bakit saken di ko po magawa, hangang sa maubos na battery ko, i've tried na to change the glow plugs but im not sure kung tama po ba yung nabibili ko, may nagsasabi dapat daw po na 11V, 12V at may nagsabi pa na 7.5V daw po dapat ang ikabit kong glow plugs, pero according sa AMCAR 11V daw po yung talagang nakakabit sa L200, which i haven't tried yet kse medyo expensive.
Need some advises, comments, suggestions, first time ko lang po kse nagka diesel engine and i dont know yet what are the secrets of good maintenance of a diesel engine.
Thank you very much po in advance!!!
January 4th, 2007 10:02 AM #2
Sir ano po yung makina nyo ? is it a 4d56 , if yes check also the shut off switch sa may gilid ng injector pump , from my experiece cause din cya ng hard starting
January 4th, 2007 11:31 AM #3
just remove 1 plug then show it the store, about the shut off valve, if busted the engine will not start.
January 4th, 2007 10:04 PM #4
sir signs ng malapit ng masira na shut off valve yung hard starting , based on my experience , yun kasi nangyari sakin last november when i was in manila :D well i could also be wrong pero have it checked at least :D
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
