Results 1 to 3 of 3
- Jul 2006
- 9
April 27th, 2007 12:11 PM #1Please help po ulit, may maliit na tulo sa may oil pan, umpisa po iyon nang nasaldak sa lubak yung oto, the following day may maliit na patak na sa ilalim ng garage, silip ko din may maliit na yupi nga ang oil pan.
Sabi po ng kakilala ko eh, konting pukpuk lang iyong oil pan, so syempre tatanggalin. Sabi palitan din daw po ang oil at oil filter and buy a silicone gasket na red.
Kailangan na bang palitan ang oil kapag bubuksan ang oil pan?
Isa pa po yung oil pressure light eh delay ang ang pagpatay, mga 5 seconds after running the engine bago mamawala ang ilaw, pero pag turnoff ko agad siya ok naman, patay agad ang ilaw. Cause po kaya ito ng oil leaking?
Kung change oil naman, ano po kaya ang magandang oil at oil filiter, kasi may nakikita ako mga oil yung W's iba iba eh. im planning to buy din sana tomorrow eh
96 vti po yung auto
Sensya na po sa madaming tanong, TY po
April 27th, 2007 05:49 PM #2
hi mach 1,
a small leak may escalate to bigger problems if left unattended since the lubrication system is subjected to a certain amount of pressure. you will definitely drain out and change the oil once you service the oil pan. dpending on the damage, the oil pan may respond to simple hammering/ flattening or will require some oxyacetlyene (red gasket - pioneer may be enough for small holes but be aware that in time, bits of worn gasket may mix and dwell in your engine). don't forget to check around the drain plug for bent bolt or poor fitting. and whilst you're at it, change the oil filter based on the car's specs to ensure that your engine gets uncontaminated oil.you will probably need 3 liters of replacement oil for your car (caltex havoline and/or counterpart). try to acquire or maybe fabricate some form of shield (plastic or g.i. sheet) to cover and protect the underside of your engine since your car seems to have a low profile.hope this helps.
- Jul 2006
- 9
April 28th, 2007 09:29 AM #3TY po sir, suggestion noted, ipacheck ko sya agad sa shop. May nabibili bang oil pan para di na pokpokin? Di naman po low profile ang auto ko, kahit mabagal ang takbo ko eh talagang malalim lang ang lubak sa pinuntuhan ko kaya ayun. Salamat po ulit.
Daming issue ng SU7:grin:
Xiaomi E-Car
