Results 11 to 20 of 21
Toyota is my choice
- Aug 2005
- 2,063
August 30th, 2006 04:35 PM #12
Also check your brakes. Sometimes, there are loose parts that only make sounds when you're backing up.
September 5th, 2006 07:44 AM #13
update .....
I was in our empty office parking lot just a while ago and I did the following:
move forward full circle with wheels fully turned to the right - no kruuug sound
move forward full circle with wheels fully turned to the left - no kruug sound
move reverse full circle with wheels fully turned to the right - no kruug sound
move reverse full circle with wheels fully turned to the left - no kruug sound
move reverse in straight line with wheels straight - kruuug sound came out
hmmm.... so is it safe to rule out the CV Joint's?
any suggestions?
September 5th, 2006 08:22 AM #14
hirap kasi hula hulaan lang ang sira ng sasakyan mo, since lalo na hindi namin nakikita iyun actual... like my first suggestion eh ipatingin mo na sa mechanic...
check underchassis
check brake
check transmission
check clutch
check engine
base sa kwento mo malamang kasi may naiipit... kung ano at saan eh hindi ko alam...
whag mo na hintayin magka kruuug at lumala ang sira worse eh masiraan ka pa sa daan... iwasan ang problema at sakit lalo sa ulo...Last edited by chuaed; September 5th, 2006 at 08:25 AM.
September 5th, 2006 08:36 AM #15
September 5th, 2006 01:12 PM #16
Sounds exactly like a brake problem, then. Have had lots of that. Just be sure the sound isn't coming from your gearbox...
September 5th, 2006 01:18 PM #17
could be the "dogbones" (trailing arms). or the rear stab links. sometimes these things loosen up in such a way that when you're moving forward, they are still properly cushioned but when you move backward there's a metal-to-metal impact.
September 5th, 2006 04:01 PM #19
Baka mababa ang clutch mo. Wala ka ba nararamdaman sa shifter stick mo pag nag eengage ka ng gear? Minsan kasi mas mahirap ipasok sa reverse.
September 5th, 2006 04:06 PM #20
Pwede din iyang differential backlash. Yung mali ang pag-mesh ng gears sa loob ng differential. Pero kung paatras lang naman, it can wait.
I avoid slots with pick-ups nearby.
PH Gov't looking to bring back excise tax for...
