Results 1 to 14 of 14
    Quote Originally Posted by cocoy View Post
    go to goodgear in libertad . under the LRT... they should have brandnew replacement rotors there.. more or less it could be just under 1000.. because i bought a rotor for my starex and it was less than 1300....
    thanks for the immediate reply !!!!!
    Feb 2006
    i got mine for 900php. pero di sya orig, i suggest kuhanin mo orig kasi yung replacement na nakuha ko mas manipis compared sa orig na nakakabit sa kia ko, to think pa na i had those stock rotors resurfaced twice before replacing them pero mas makapal pa rin sila dun sa pinalit. well if you could get replacements na makapal din why not di ba?
    Feb 2006
    mga bro....how much pa-reface? 1pc lang ha..
    diba maganda bnew kesa pa-reface?
    tia
    There are replacement higher performance rotors made by R-spec. One of boybi's pals has a Nissan Patrol wearingi R-spec cross-drilled rotors for improved braking performance.
    Feb 2006
    tia
    if i remeber it right, i think it was around 600-700php yung pa resurface ko per rotor disc. well yun ang presyo ng machine shop dito sa las pinas ah.
    mas maganda nga brandnew pero nagtitipid kasi ako nung time na yun kaya i had it resurfaced na lang
    Di ko recommend reface. ninipis na yun rotor and it tends to warp during hard braking. baka mabiyak pa yan. at the stated price above mas mabuti pa brand new either oem or replacement.
    Nov 2003
    cross drilling will not improving braking distances it just helps in evacuating brake dust and gasses which help the rotor cool down sooner.
    sir otep they available for the starex?
kia pride rotor disc
