Results 1 to 3 of 3
November 2nd, 2007 10:14 AM #1
Gusto ko lang mabawasan itong body roll ng Hyundai Matrix ko sa cornering. Wala talaga syang stabilizer bars kaya wala akong makukuha sa casa. Kailangan pa bang paggawa pa ako ng pasadya o madali na lang itong hanapan ng tamang sukat? Saan ba makakabili ng maganda?
Thanks!
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 5th, 2007 08:44 AM #2if there is no place/provision to mount them then i suggest na wag mo nalang ipagawa.
November 5th, 2007 12:06 PM #3
It's hard to custom fabricate anti-roll bars... there's a proper length and thickness that you need to consider in order to provide proper anti-roll function... too stiff and you'll have a very twitchy vehicle that rides badly, too soft and you might as well not have one at all. Do you really want to prototype half-a-dozen bars looking for the right one?
Strut-tower bars are easier to make... the only requirement for STBs is that they link the strut towers solidly. As the Matrix doesn't have a firewall between the two rear strut-towers like sedans do, this might help... depending on how high up into the car the struts go... but not as much as a stabilizer... and you might have to cut some sheet metal and will definitely have to cut the covers over the shocks.
See if you can upgrade your shocks and springs... this will help immensely without resorting to cutting.
Thread was made nung 2018 pa po sir.
