Results 1 to 10 of 45
September 14th, 2005 12:46 PM #1
this may sound odd.. dumb (?) [wag naman sana, nagtatanong lang po]
i was used to starting my car with a little delay.. like.. you insert the key, twist it once, then lights, and everything (electrical) goes up, then maybe about 4-6 seconds, i start ignition.. one person told me that this is no good.. di naman daw diesel ang sasakyan so... so anyway.. is this bad? with the pause before ignition? or talagang kelangan na start agad (turning the key to I then II immediately?
September 14th, 2005 12:50 PM #2
in our 323, when you put the key in the start position, it will beep for a few seconds. naturally I don't start the engine until the beeping stops.
September 14th, 2005 12:55 PM #3
in my car... beeping starts kasi it checks all the other thingys in sensors, airbags, stuffs like that, then beeps (lastly) that the seatbelts are not fastened.. i dunno if there's a difference in pausing and just starting it rightaway.. i start ignition when the beeping stops..
September 14th, 2005 01:05 PM #4
hehehe ang galing nito.. i sometimes do that para lang macheck ko kung off ba aircon ko and everything bago ko start talaga...
September 14th, 2005 01:09 PM #6Originally Posted by mazdamazda
September 14th, 2005 01:16 PM #7
pausing for a few seconds lets the fuel pump pressurize the fuel system. in my experience, not pausing may cause harder starting.
September 14th, 2005 01:18 PM #8
doesn't make a difference. parang *** yan...either isaksak mo at i-start kaagad, o medyo i-tease mo muna ng konti...ganun pa rin yung outcome :lol:
September 14th, 2005 01:18 PM #9
I don't see any problem with either method unless it is strictly specified in the operating manual. Kasi pag-start naman papatayin halos lahat ng devices sa current draw ng starter.
September 14th, 2005 01:29 PM #10
basta ako, the following procedures work:
a) Put in the key
b) Take a deep breath three times.
c) Close eyes for around 5 seconds.
d) Turn on the ignition.
wala namang adverse effects sa oto ko. although after i do step d, medyo inaantok and relaxed na relaxed ako....
Xiaomi E-Car
