You can install 1 10-12 inch fan to cool it down on traffic. You also need a separate Heavy Duty relay so you will have enough current to run it more sufficient. do NOT tap the Power wire to the A/C relay. Run it as a different system so when its cold already you can shut it off and less drain for you battery and less load for your alternator.
