Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jan 2003
    has anybody herd of or tried this pinoy invention, Khaos super turbo charger? 6500 with instalation na daw and installs in 20 mins lang. ok kaya ito? here's the link www.khaos.com.ph
    here we go again.
    mukhang dati na yan pinalitan lang yung pangalan na Khaos.
    also meron yan sa F150 ng bayaw ko, wala naman effect.
    also sana naman alisin na nila yung turbo super charger sa name, kasi baka naman akala nga mga "iba" instant HP gain sila at magkarera sa kalye.
    and unless ma satisfy si Yebo dun pa lang ako maniniwala he..he
    here we go again and again and again! notorious na ba ako sa pagka-skeptic at ako agad nasa-isip mo nyahahahaha!
    i hope i do not get misunderstood by people here, i just ask questions because it's the only way to protect ourselves from scams and "inventions" that only rob us of our hard earned money.
    tignan ko ang link, malay mo this is one of those one-in-a-million that does what it claims.
    time out muna, magbabalik...
    dati na to binigyan lang ng new name, super turbo charger by mr planas. it leans your air/fuel mixture by adding a small air filter on the intake manifold. since the added air does not pass through the O2 sensor then the fuel management system will not be able to detect it and thus the a/f ratio will lean out. on carburated engines the air filter inlet port is added after the carb, on efi it is after the O2 sensor.
    imho, it will save gas and also lower CO, but the claim that it will lead to more power output is something that needs to be tested. if you lean out the air/fuel ratio what normally happens is that the power output will go down, not up.
    if you go for fuel economy, then i think it's ok (that is, i think for now until i find out more about this product!). you would not want to put this on your engine if you like to overtake or carry heavy loads often, kakapusin ka sa arankada.
    so it's part true and part scam. imho lang ha.
    Aug 2004
    I checked the website...and found this , I quote:
    ". It minimizes other pollutants like hydro carbon, carbon
    dioxide, oxide of nitrogen to less harmful level. Since
    KSTC achieve efficient combustion it can prolong the life
    span of the engine, spark plug, mufflers, and engine oil."
    Whenever claim for minimizing CO2 emission and efficient combustion is made, be very cautious...
    CO2 is the normal product of combustion...in fact, you get more CO2 as combustion becomes more efficient... that's where the CARBON in the fuel goes.....
    kung ako lang bili na lang ako ng K&N, same effect. kung pwede CAI pa, sure ka pa na talagang lalakas engine mo. more power on the engine will also mean less fuel consumption if you drive it easy.
    Jan 2003
    ayos talaga sa tsikot!!!!! my bro-in-law saw the ad on a tabloid... and asked me kung ok. sa tingin ko nga parang pipe lang na nilagyan ng kung anong parang valves tapos binenta ng 6500.
    so if its after the carb pwed kang maglagay ng small taiwan filter to the same effect din kaya?
    Apr 2004
    KHAOS..rhymes with chaos..hmmm..chaotic na ang sitwasyon ng economya natin tapos me kumakalat pang P6500 gadget confusing people's weary minds..?!
    this is too burdensome..hanap na lang tayo ng mura na epektibo pa..
    the product should be renamed:
    KHAOS SUPER TUBO CHARGER
    ser yebo, magtayo ka na nang testing consultancy for automotive aftermarket products.....hehehehe
    tapos request lang, una mong i-test yung mga invention ni vee-val....hyukhyukhyukhyukhyuk...:bwahaha:
    siguradong masaya yan.....:bwahaha::bwahaha::bwahaha:
    wow, the thingie comes in a number of colors... ;)
    Jun 2004
    hindi kaya fixed yung a/f ratio ng khaos, maraming kasi factor para maging efficient ehh.. humidity, atm pressure, atm temp, air density, pati RON rating that varies on time stored..kaya kung fixed ewan..hehe..sana nga effective..>>
    kaya nga sabi sa website nila it must be installed by their technician, kasi pag masyadong lean ang mixture pwede masira car mo, mag-knock ang engine.
    kaya nga for me, even if my mind says it could work my self preservation instincts say don't buy hehehe!
    P6500 ang price! no shet! i have the same filter here on the rig, i can install that on my car if i want to. sa akin na lang kayo bumili, half the price lang nyahahaha! red color ng filter, washable din parang K&N, nyahahaha! at buy 1 take 1 pa, libre ko lang kukunin dito nyehehehe! yun lang pag sumabog makina nyo walang sisihan ha!
    Aug 2004
    ah... hindi ko nagets yan nung una... pero LOLOLOLOL!!!
    impulzz, kay kuya yebo ka na lang bumili..nyahaha langya..sobrang dami na talaga ng mga manloloko ngayon.. tsktsk
    May 2004
    Walang hiya P6,500.00 para sa maliit na so called khaos turbo charger? I don't even have that kind of money these days, isang buwan na suweldo na yan.
    Aug 2004
    Ayan na... sinuportahan na ng gobyerno at may balak pa atang marsponsor para ma-test sa US. :D
    Wednesday, September 01, 2004
    Filipino’s invention the
    answer to high oil prices
    By Jonathan Vicente , Reporter
    FROM zero to hero, the Filipino inventor Pablo V. Planas is now reaping the rewards for keeping faith in himself.
    As early as 1973, Planas had come up with an innovative vehicle device he called the Khaos Super Turbo Charger (KSTC) designed to get more from the fuel he buys while shooting for zero pollution and engine durability.
    The 67-year-old Planas said he invented the KSTC at the height of the Arab oil embargo when the price of fuel went up and the Philippine government had to enforce a fuel-rationing program nationwide. Then, as now, Planas said he was confident that his invention was truly on the right track.
    Planas started out as an operator of a passenger jeepney plying the San Juan-Manila route. It was then when he began tinkering with vehicle engines to figure out how he could save fuel. He noticed that unburned fuel was still present in the exhaust fumes and that the same unburned fuel caused air pollution. Challenged, he developed the gadget that would help the engine of his jeepney burn fuel efficiently and lessen his expenses for diesel oil.
    Planas installed the device and on the first day, he saved P2 worth of fuel. During the early seventies, P2 still counted for a lot.
    Thinking of the welfare of his colleagues in the small transport industry, Planas produced a few more devices and tried to sell them to his fellow drivers for P25 each. Unfortunately, there were no takers.
    Not losing hope, Planas began offering his invention for free to his fellow drivers.
    The drivers afterward realized that they were saving at least 24 percent of fuel and earning more after setting aside the P8 boundary to be paid their operators.
    In 1974 Planas was able to dispose of 25 units of his antipollution and gas-saving device combined into one. In that same year his invention caught the attention of President Ferdinand Marcos, who ordered a thorough evaluation of the gadget by the different government agencies, including the Armed Forces of the Philippines.
    Documented tests showed that Planas’ device has the capability to save fuel by 15 percent to 50 percent when installed in a vehicle.
    “Halimbawa, kung P1,000 ang ikinakarga mong gas, aabot sa 40 percent o P400 ang natitipid natin kapag may Super Turbo Charger,” Planas said.
    In 1976 results of the technical test showed that out of 44 various inventions, the device invented by Planas was first among gas-saving equipment.
    In 1977 the KSTC proved to be very effective as an antipollution device with zero pollution based on the test and evaluation reports of the National Pollution Control Commission.
    The findings showed that the device, using 100 percent complete combustion, could reduce toxic emission to zero while giving the engine from 25 percent to 30 percent additional power.
    “Every car-manufacturing company should add this kind of equipment to their list of equipment in the assembly line. But we know there is collusion between these companies and the gas firms,” Planas said.
    The equipment, which is being sold in selected markets, has caught the attention of thousands of car owners and car-parts makers. No less than the Department of Energy has indicated in its findings that Planas’ statements are true. Of the vehicles with KSTC tested by the department, findings showed savings ranging from 26.84 percent to 70.21 percent.
    Last week, Planas was called to Malacañang to discuss with government officials how effective his invention really is.
    “I have talked to Energy Secretary Vince Perez and Secretary Rigoberto Tiglao and I am happy because after they had used the device, they promised to help me market my invention. Natutuwa din po ako dahil meron nang suporta mula sa gobyerno at pribadong kumpanya. Nabibigyan ng break ang mga maliliit na taong tulad ko,” Planas said.
    Besides the government, Planas is also getting support from the businessman Gerry Acuzar, who owns the New San Jose Builders Inc., and other businesses in the banking and construction industry.
    Planas said Acuzar has been providing financial and business muscle to the product and there are talks with international distribution companies to market the KSTC in Europe and the Americas.
    wag magpaloko sa mga gunggong na yan!!!
    eh ang katapat lang ng invention nya is by leaning out your AF mixture! ganun din ang effect... almost zero "emmission" then improved fuel consumption... ang problema naman is in the long-run masisira ang makina mo...
    sa mga hindi naka tune-up or maintained na vehicles, baka pwede yan...
    my officemate has one on his toyota corolla 1990 GL and he claims that he is conserving fuel at gumanda raw batak ng sasakyan nya. maybe para sa mga lumang carburated vehicles effective sya. di ko naman pwedeng sabihin na yung kaibigan ko naiimagine lang nya yun kasi daily ride nya yung car at umuuwi sya sa batangas every weekend. :-)
anybody tried this product???
