Hello Guys... have anyone there encountered or a user of hypervoltage kit?? any comments or bad experiencesI came across this store and the manager introduced the product to me..here are some of the infos I've searched::
[SIZE=2]The Hyper Voltage System is designed to stablize the flow of voltage from the battery. Demand from your vehicles electrical components, such as lights, stereo, gauges, even heavy throttle can cause voltage fluctuations. The Hyper Voltage system helps significantly to reduce the load on the battery by storing engergy and releasing it back to the battery as needed to stabilize voltage. The end result is a more efficiently operating electrical system , which can pull out the full potential of your vehicle. When used along with thy Hyper Ground System, both the flow of electrons through the ground circuit and the supply of electricity from the battery are tuned for maximum efficiency.
I'm planning to buy kasi if this is effective ..Thanks!!!![]()
[/SIZE]
