Results 11 to 20 of 23
Tsikot Member Rank 4
- 2,719
- Mar 2007
- 4
April 13th, 2007 07:41 PM #13
ano ba itsura nung condenser sa contact point? ito ba yung distributor cap mismo (where the spark plug wires are connected) or yung rotor na umiikot na nagko kontak sa apat na contact point sa dist. cap.
thanks.
April 14th, 2007 12:01 AM #14
hay naku talagang dying breed na ata ang gumagamit ng contact point ignition system sa cars nila. Yun condenser is the metal tube like thingie na usually nasa side ng distributor. may isang wire ito na naka screw sa metal part ng distributor pero insulated ito kasi sa contact point ito naka connect.
April 14th, 2007 11:55 AM #16
Condenser is an electrical device that acts to store an electrical charge preventing voltage surges. http://www.jetav8r.com/Vision/Ignition/CDI.html
April 14th, 2007 12:09 PM #17
Usually most of carb engine using conventional type of ignition system, the switching on and off of the primary voltage was done with a set of Breaker Points (contact point) but some of them in early 90's they are using an electronic type of ignition system, the points were replaced with a control module and the lobes on the cam were replaced with a trigger device.
April 14th, 2007 07:51 PM #18
parang walang condenser ang 1990 corolla, have a chilton's manual and ako mismo nabuksan ko na ilang beses distributor nyan, nakapag palit na ako ng pickup coil and ignition coil at wala ako nakikita na condenser as described by afrasay and the link above.... hmmnnn... i may be wrong
April 15th, 2007 04:54 AM #19
Depending on the engine type of the vehicle. For example, 4A-F engine used a carburetor while 4A-FE used electronic fuel injection system. Condenser is attached on outer part of distributor. http://tsikot.yehey.com/auto-classif...5_1_-large.jpg with a blue wire.
April 15th, 2007 07:50 AM #20
to kaya yung condenser? pano mate test ito kung okay pa or needs replacing?
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
