Results 1 to 10 of 12
- Jun 2005
- 4
June 17th, 2005 07:08 PM #1i have a 1st gen CRV, matic. ang problem ko pagshift ko sa 1st gear, may lag time na mga 2 seconds bago mag engage. ano kaya problema? pag-apak ko agad accelerator pedal, may malakas na thug kang maririnig. pls help!!!
June 17th, 2005 09:21 PM #2
rough shifting and shift shock are usually due to worn-out automatic transmission oil. since it's a 1st gen, baka matagal nang hindi napalitan yung ATF mo. you could have a mechanic drain and replace all the tranny oil...
June 17th, 2005 09:41 PM #3
Put some quality synthetic ATF when replacing your tranny fluid. Makes miracles, your car will shift smoother.
June 17th, 2005 11:17 PM #4
Try to check your throttle cable adjustment as well... tightening or lessening the slack can help a bit. This may affect fuel consumption a bit though as the throttle can be more sensitive to pedal inputs (depending on the car).
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 18th, 2005 11:16 AM #5try redline atf! it's some good stuff!
got a couple of liters pa in the shop if you need some.
- Jun 2005
- 4
June 18th, 2005 03:22 PM #6just replace atf, ganoon pa rin. may mafefeel 2 mahinang thug bago mo pwedeng apakan accelerator pedal. kaya laging binubusinahan ako ng ibang tsikot pag nasa unahan ako ng stoplight. ty everybody for ur comments.
- Nov 2003
- 3,848
June 18th, 2005 08:01 PM #7could also be the strainer of the tranny... pero you'll have to pull it down before you can check it. or try to see if the cable can be adjusted.
how is shifting once it is in gear? may delay narin?
- Jun 2005
- 4
June 18th, 2005 10:41 PM #8pagnakagear na walang problem, sa 1st gear lang. natry ko crv ng bro, di naman ganun. kya pagshift ko sa 1st gear have to wait bago apak accelerator pedal. oo nga pala pati reversve ganuon din. ty speedyfix for the reply.
- Nov 2003
- 3,848
June 19th, 2005 10:36 AM #9uhm, then see if the cable can be adjusted nalang siguro... it's a long shot but it could be that...
- Oct 2006
- 14
March 21st, 2007 03:19 AM #10
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
