Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 1970
    Wow often should you have all the fittings done?
    Once a year? Twice a year?
    I read somewhere that you should get it done after every underwash just in case ma-wash away but it seems unlikely cause naka seal naman yung fittings.
    I had it done na rin anyway right after I got an underwash the other day and asked the guy there. He said "pag mukhang wala nang laman...palitan na."
    Diba naka seal nga... so how do you check?
    ako every 5000 kms sabay sa change oil. mura lang naman e, around 12 bucks per fitting.
    ako every year or 20kkm. or whichever comes in my mind. :mrgreen:
    Jan 1970
    I have 12 fittings to be lubed (mits montero SWB). last time I had it done they charged me 30 bucks per fitting = P360.00
    Kung every 5000 km thats about 3-4 times a year (depending on usage).
    Siguro I'll compromise na lang with twice a year before and after rainy season.
    30 bucks lipat ka na lang sa ibang gas stations merong 7 bucks lang (caltex a. lacson) 12 bucks (shell retiro)
    just ask around mabilis lang naman iyan gawin less than 10 minutes tapos na yan.
    ano po bang mga fittings ang tinutukoy ninyo?
    Thanks
    Jan 2003
    Quote Originally Posted by artpogi
    Thanks
    ArtPogi, what i understood as I was reading this thread, ay ito yung mga GREASABLE FITTINGS, like sa MitsL200 PICK-UP ETC, wala po nito ang Lancer series o kotse, ewan ko lang sa ibang modelo.
    clone :lol:
    30 bucks per fitting!!!!
    mura na yung nabanggit ni sir Rediesel na 7 per fitting...dapat nasa 15-20 lang per fitting...
    Quote Originally Posted by clone1537
    Thanks
    clone :lol:
    ah okay, thanks Clone
    Jan 1970
    I know...mahal talaga. nag pa-under wash lang ako nang na-isipan kong mag pa-lube tapos nung nakuha ko ang bill P30 daw per fitting. Na-taga yata ako. I had it done sa Dallas Service center sa Morato near corner of E. Rodriguez.
    Lesson learned...ask how much first. mahirap pag nagawa na. buti na lang yun lang yon and not something major.
    Quote Originally Posted by chieffy
    sa marikina P50 per (shell). ang mahal pala sa amin. baka may kasamang teflon yon ah.
    12 per fitting na lang sa Shell Retiro? Dati 14 ha. Buti pala hindi ako natuloy dati. hehehe.
    Hindi basta basta maalis ng underwash ang grease. Most of them are inside the components or are protected by rubber boots/grommets. Yung grease gun nga nahihirapan i-force out yung old grease, eh.
    Jan 1970
    tanong lang po..
    lahat ba ng pajero kailangan ng lubed sa fittings.. .. yung sa akin 3 doors.. yung converted na pajero.. ano nga pala ang local term ng fittings baka kasi hindi maintindihan pag sinabi ko fittings he.he.. ;) and ilang fittings meron ang pajero..
    pasensiya na ha.. dont know what is fittings kasi eh..
    marwen
    marwen,
    The gas station will know these fittings. Techinically they are called zerk fittings or grease nipples. Alam din ng gas station iyon. Almost all truck-based vehicles have fittings that can be lubed.
    More than ten fittings ang naaalala ko. Hindi ko kasi makita yung listahan, eh. Meron sa front and rear drive shafts (both ends of both driveshafts pa ata). Sa pitman arm, sa ball joints and kung saan saan pa. Usually concentrated sa front suspension.
    Jan 1970
    oki doki... hehe...
    masyado na mahal pag lumampas ng 20
    Jan 1970
    sa honda civic ba (model 97) me mga fittings ba that must be lubed?
    may fittings ba ang kia carnival/sedona??
    Jan 1970
    Always check that they are changing the grease in all the fittings. There are some fittings that are hard to reach and they might just say that they did them when you're not looking. Alam mo naman ang ibang mekaniko pag di mo kilala...minsan tinatamad.
    Dec 2002
    An alternative is to buy your own grease gun (about P400) with flexible rubber tip and specific grease cartridge. Gives you the option to buy special grease, eg, grease with moly, synthetic grease rather than the regular gas station grease. You can grease up whenever you feel like it!
How often to get fittings lubed?
