Results 1 to 4 of 4
    Apr 2006
    1. are there ways to prevent or remove oil leaks?
    i noticed this because everytime i check my engine oil level, it's surprisngly at very low levels from previous.but i already notice oil leaks...
    2. what can i do?
    3. how much does it cost i i let this be serviced?
    thanks!
    Depende yan bro kung nakita mo na source ng leak... Usually kung gasket leaks, you don't lose much oil, pag blow-by ang malakas kumain ng oil.
    Aug 2005
    to prevent oil leaks replace oil seals or what the call "eliminate" leak.. cheap parts but labor is kinda "mahal"
    trace where the leak(s) located
    cost would depend on the labor and parts
    Nov 2003
    to remove a leak, replace the seal.
how to prevent/remove oil leaks?
