Ano po ba SOP after bumili ng 2nd hand 4x4 pickup? Sa ngayon change oil, air filter and oil filter. Check the timing belt kung kelangan palitan. Need more info pa sana. Tnx!
try to observe first...for the mean time, ok na po muna ang change oil and filters. kung wala naman pong nararamdaman, just leave it as it is. i think timing belts need to be replaced after 100k kms ata. always check for water level on your radiator to prevent overheat, sama mo naren yung pag check ng brake and clutch fluid at least once a week since 2nd hand yan. have the suspension checked naren for further assessments.
change the fluids (brake, power steering, clutch, coolant, etc.). for the timing belt, refer to your owners manual to make sure ilang mileage kailangan palitan ang timing belt. usually nasa 100k kms yun. pag nagpalit ka timing belt sama mo narin water pump and tensioner bearing para isang baklas/kabit nalang. repack bearing and change grease.
thank you very much sa lahat ng replies. will change brake and clutch fluids tomorrow. Medyo malambot na clutch...Sa ngayon nakikita ko tagas ay yung gear oil. changed oil seal na and replaced the gear oil na pero may tagas pa rin....
