Results 11 to 16 of 16
- Jun 2011
- 26
August 26th, 2011 01:46 PM #11nosebleed ulet sir... panu baliktaring ang polarity at panu ko malalaman kung ganun ang setup ko..
pasensya na sa mga tanung ko.. newbie lang ako sir.. gusto ko lang matuto kalikutin yun auto ko.. sabi nga nila, the best driver knows what's inside his car..
August 26th, 2011 01:55 PM #12
gawin mo na from + (amp) to + (spkr) and from - (amp) to - (spkr). pareho kada channel.
di tumunog yung speaker? baka naman walang signal from head unit to amp. check mo. kung may multi tester ka pwede mo macheck yan. o baka naman naka set sa 0 yung gain. kung sakali, dahan dahan lang ang pihit.
- Jun 2011
- 26
August 26th, 2011 02:15 PM #13sir, ganun po yun ginawa ko before. (positive amp to speaker and negative amp to speaker) kaso walang tunog na lumabas..
pero may gain naman sya..
August 26th, 2011 03:02 PM #14
may signal ba from HU? try mo ikabit muna yung speaker diretso sa head unit. pag di tumunog, baka sira yung cable mo.
August 26th, 2011 10:05 PM #15
Mga sir, pag binaliktad mo ang polarity ng speaker sa amp, say yun positive speaker output nung amp to negative terminal nung speaker, it will cancelled the signal in front and rear imaging(say 0 degrees in front and 180degrees sa rear), so, kelangan mo rin baliktarin yung sa polarity ng front speaker para they sound as one, wala naman pong nakakalito sa set up na ganyan e, basta follow na lang po kayo sa given instruction, pinakamadali nyan is ang gamitin nyo na lang dyan is yung head unit speaker output, mas magiging malinaw pa yan kesa ang gamitin nyo is yung X-12 na amplifier, wala pa kayung ibang magiging problem kase meron na pala naka abang na speaker output sa rear.
- Jun 2011
- 26
September 5th, 2011 03:59 PM #16salamat sa mga reply!
nakabit ko na po yun speakers at tumutunog na sya..!!
kaso parang nawala yun base nya... humina yata... dato kasi parang nakacrossover yun bass sa ch1 to 2 eh ngayon channel 1 na lang..
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
