Results 1 to 10 of 23
- Aug 2003
- 9,720
July 10th, 2005 07:56 PM #1share your techniques naman. i've seen some auto shops use an air compressor to flush out the oil; i've heard some people letting the oil drain overnight para siguradong ubos.
July 10th, 2005 09:39 PM #2
drain overnight then flush with new oil. you can also save the flushed oil since its still clean anyway...1 litre would do.
- Jun 2005
- 113
July 11th, 2005 01:33 AM #3Originally Posted by pitbullz
I usually dont bother "flushing" the remaining oil out of my engine. I change my engine's oil regularly and I doubt if the 1/8 cup of old oil is going to shorten the lifespan of the 3-4 quarts of fresh oil in a 3-month period.
Besides, some people only change their filters ever other oil change, and they don't seem to notice any problems.
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 11th, 2005 12:17 PM #4try not to use compressed air. flushing should also only be used kapag madami na buildup inside the engine (buo buo na yung oil), since it contains petroleum which can eat away at the oil seals.
July 11th, 2005 05:58 PM #5
ah masama pala na binubugahan ng compressed air when draining? didnt know that, next time di ko napapagawa yun. just drain until none is left.
- Aug 2003
- 9,720
July 11th, 2005 06:40 PM #7
run your engine until oil temp starts to rise. Or you can drive around your neighborhood until the oil temp rises to its normal temperature as indicated by your temperature gauge. Heating the oil makes it less viscous, or more fluid, so it flows out easily. drain with the oil lid open to prevent vacuum effect. pag konting tulo na lang ng oil, remove the oil filter (make sure na masasahod mo yung tatapon na oil from the filter). No need to blow with compressed air. Compressed air tends to have some moisture since compressing air condenses the water vapor inside the ballast tank of the compressor making the pressurized air moist. Moisture is bad for your engine internals, it may cause serious corrosion problems.
pag totally ubos na yung oil, (which will take about an hour only if you started with a warm engine/warm oil), re-insert the oil pan nut and put new oil filters then refill with new oil. hth ;)Last edited by rsnald; July 12th, 2005 at 06:34 PM.
July 11th, 2005 08:09 PM #8
Thanks for that explanation about the dangers of using compressed air, rsnald. One of the problems though if one is having an oil change at a gas station is that the supervisors usually want to make the process as fast as possible (more customers, more money), so they would insist that the mechanics use compressed air to speed things up.
Kanina nga nagpa-oil change ako sa Caltex dito sa amin, gusto pang gamitan ng flushing oil yung makina ko, buti na lang pinigilan ko sya.
SiRaNeko
- Jan 2003
- 973
July 11th, 2005 08:36 PM #9Originally Posted by speedyfix
question
do all flushing oils have pertroleum? i remember reading before that caltex power flushing oil dont have petroleum, hence safe to use. though its not recomended every 5k. every 10k lang daw
- Nov 2003
- 3,848
July 11th, 2005 09:27 PM #10i'm not sure about all but most do i think. there is no real need to use it naman unless super sama na ng condition. the only reason that gas stations try to encourage it's use is because it will add to the sale and move their products.
The hybrid release was also basically an all-new model release for TMPI, I think.
2021 Toyota Land Cruiser LC300
