Results 1 to 5 of 5
    Jul 2003
    brus, sensya na at andito uli ako para magtanong. may tumatagas kasi na langis mula sa valve cover. dun sa side ng distributor (corolla 92 GL). check ko eh ndi naman sa distributor kasi kakapalit ko din lang ng oil seal nun.
    dati kasi naglalagay ako ng silicone gasket kaya lang inalis ko na kasi delikado daw yun at baka bumara sa daluyan ng langis. kanina hinigpitan ko na rin yung turnilyo pero yoko sagadin at baka ma loose thread na.
    nway, anu kaya solusyon dito??? yun sanang ndi na gumagamit ng silicone gasket.
    tnx.
    replace your valve cover gasket with an OEM one.
    Jul 2003
    ok tnx!!!
    Aug 2004
    agree ako ky afrasay. pag mayrun pa rin tulo. top overhaul na kailangn dyn. sana hwag nmn.
    Jul 2003
    top overhaul??? i dont think so. valve cover lang nman problema at ndi naman yung mga valve mismo. i dont know how a top overhaul would solve an oil leak in the valve cover unless you change the gasket as afrasay suggested.
    nway, will try to look for that gasket.
    tnx!!!
how do you fix oil leak in the valve cover???
