Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    I'm not trying to be a cheapskate . . . just being practical.
    Any idea?
    Feb 2007
    Remove loose dirt/dust. Soak/wash with diluted joy liquid detergent and dry. Apply small amount of singer oil.
    Sent from my Nokia5110i-VgT using Tsikot Forums
    Jul 2013
    pwede po kaya yun engine oil na fully synthetic 5w 40?
    Feb 2007
    No sir.
    Engine oil is a lot viscous, 97 vs 9.6 *40degC. This means pwede magform na gum ang dust sa filter if you do.
    Feb 2014
    The practical move is to use k&n recharger kit. Subok na yan e. Using detergent and other oils can damage your filter or engine.
    Jul 2013
    How do you apply singer oil? Spray it directly to the filter?
    Posted via Ay****
    Apr 2012
    kapag oily at sobrang dumi, I sprayed it w/ degreaser then soak/wash it with dishwashing liquid. after washing, I bring it to my neighbors vulcanizing shop and blow dry it with compressor air. kapag sinisipag ako, nilalagyan ko ng recharging oil ;) lately hindi na, I run it dry as it is na lang and ok naman. btw, make sure to clean your MAF sensor too, it makes a lot of difference kapag nalinisan yung MAF sensor.
    Jul 2013
    pag wala pong oil hindi po ba naapektuhan yun filtration capability ng KNN?
    sir pano po linisin MAF sensor and every kelan po ginagawa yun?
    5 km nalang kasi mag ffirst cleaning ako :D
    I use engine degreaser also to clean it then use water & dishwashing liquid for final cleaning. Air dry lang ako na mga 1 day tapos I use 2t oil.
    Apply ko lang 2t oil sa topmost part nung filter tapos i let it drip down. After a day okay na yan. First time ko sobrang dami nga 2t na nagamit ko, dapat kunti lang pala, mga 50ml would do. 2 days yan kay may reserve ako na air filter. Every 15,000kms ako naglilinis.
    Jul 2011
    Quote Originally Posted by RF02 View Post
    Naapektuhan syempre, dyan nga nagdedepende yung filter, the dirt sticks sa oil kaya hindi na dumidiretso sa engine.
    the filter media is somewhat more of a filter oil holder than a filter itself, it does stop dirt, but not as much as
    a media with the filter oil.
How to clean  K&N air filter without buying the K&N filter clean and recharge kit?
