Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Thanks for your inputs fellow Tsikoteers. Pero may hirit pa ako:
    My friend suggested water+Joy dishwashing+rubbing alcohol as cleaner & WD40 as oil. What do you think of these replacements?
    Apr 2012
    Quote Originally Posted by RF02 View Post
    pag wala pong oil hindi po ba naapektuhan yun filtration capability ng KNN?
    sir pano po linisin MAF sensor and every kelan po ginagawa yun?
    5 km nalang kasi mag ffirst cleaning ako :D
    apektado at less effective ang filtering niya kapag dry, sa oil kasi kakapit dapat yung dumi. pero mas madali naman huminga makina mo kapag dry. when applying oil, just be careful lang not to put too much oil. nung bagong bili mo yung K&N mo napansin mo naman siguro gaano siya ka-oily ;) kapag sobra lagay mo ng oil, malamang kakapit sa MAF sensor probe mo yung oil at dumi, hindi masyado madetect nung sensor yung air flow so mahina hatak.
    unscrew mo lang yung sensor, then spray mo ng electronic contact cleaner yung sensor probe. kapag natuyo ikabit mo na. ramdam mo malakas ang hatak. you can clean it same time sa filter, kung madumi na yung filter malamang madumi din yung sensor probe.
    Quote Originally Posted by jjmd3_787 View Post
    Don't use wd40. Remember hahalo sa engine mo ang air coming from the air filter. Use 2t oil. That is the best that you can do. Diesel man or gas ang engine mo.
    Jun 2012
    mas ok yung 2T oil kaysa singer oil?
    Quote Originally Posted by dct View Post
    yes sir!
    Apr 2014
    Noob question guys;
    Where is the MAF sensor located? un ba ung malapit sa filter box? TIA
    Any suggestion where i can buy cheaper knn filter for my civic fd?
    Posted via Tsikot Mobile App
    Apr 2012
    Quote Originally Posted by TimPam View Post
    Noob question guys;
    yes, after your filter box. i measure niya yung mass air flow. meron ka pa isang sensor, yung MAP sensor (manifold absolute pressure) naman bago sa intake manifold. both of them are use by the engine ecu to calculate yung AF ratio mo.
    Apr 2014
    TYVM sir monty sa response
    Jul 2011
    I saw sa concorde before na meron sila filter cleaner and recharge kit na mas mura,
    but simota yung brand, i dunno if parehas lang ng quality, but if your in a budget,
    pwede mo itry.
How to clean  K&N air filter without buying the K&N filter clean and recharge kit?
