if your headliner is made of stretchable fabric, it usually has a urethane foam backing that in time crumbles to flakes or dust and loses its grip on the roof material. if it uses leatherette, it is directly fastened using rubber based adhesive. for diy reinstallation, you need to scrub the area of the old loose insulaltion foam material and the adjoining surfaces with a nylon scrub. then, you can spray 3M brand contact cement (rugby or rubber cement as what it is commonly called in the country)on the inner roof surface. have an assistant or two assist in the installation for alignment of the fabric. careful installation is a must or you miss all the pride installing it right
