Results 1 to 10 of 10
Tsikot Member Rank 3
- Oct 2003
- 734
September 18th, 2004 12:28 PM #1asko ko lng sa tingin ko marumi na loob ng exhaust system ko ksi madami carbon deposits sa tip sa likod so malamang marami din carbon sa loob. nililinis ba ito? at kung magpapalinis ako saan recommended? paano ginagawa nila dito? thanks
September 18th, 2004 12:38 PM #2
any gas station can do it for you,libre if u have ur car washed w/ them.ask 1st tho....what they do is place the hose inside ur pipe while covering the opening w/ a rag,when there's enough water inside,they take out the hose & the rag & u start the engine & rev it up til all the water's flushed out,then u shut off the engine & repeat the process a coupla times
- Oct 2003
- 734
September 18th, 2004 01:00 PM #3di kaya pumasok sa makina yun. plano ko ksi idisconnect yun headers tapos dun padaanin yun tubig flush tama ba yun? yun mga mufflers shops do they do cleaning nag aalangan ksi ako baka pag punta ko dun baka sabihin palit buong exhaust system eh cleaning lang naman kailangan?
September 18th, 2004 01:45 PM #4
it doesn't help you, unless the pipe is so dirty that it's clogged.
although if your tip is chrome, it's always nice to keep it nice and shiny for looks.
September 18th, 2004 02:46 PM #5
may cleaners naman para sa mga tips. paminsan minsan lang ang flushing baka pasukin ng tubig. some owners have exhaust blockers to keep the water from going to the engine.
dude, kamusta na nga pala? hehe napagawa mo na ba sounds mo?
- Oct 2003
- 734
September 18th, 2004 02:55 PM #6di pa eh bitin pa budget eh.
correction yun problem ko nga pala ay sa buong exhaust system from headers to the tip of the muffler----how do you clean the entire pipe yun loob the entire stretch? susundutin ba ito or what?
September 18th, 2004 07:27 PM #9Originally posted by hagiber
okay lang ba ito kung may catalytic converter?
Ask pajerokid if he still has the pic of his old Pajero with welded pipings to clean his exhaust system. Just make sure your exhaust system doesn't employ a cat converter before doing it.
September 20th, 2004 11:41 AM #10
and usually sa diesel lang ginagawa to... if your gas powered car has black soot, something is wrong sa makina mo.
