Results 1 to 5 of 5
    under ur rides' hood/bonnet
    factory/aftermarket insulation- whats it really for???
    aftermarket: is this ok??
    aftermarket i've seen:
    -looks like roof insulating material (silver color on 1 side sandwiching white foam like backing) silver color side will face u when u open hood
    -usually meausured to cover inside of hood and glued on using rugby (i have it on good authority that heat resistant double sided tape is recommended here instead)
    Were you referring to this product?
    - Engine heat shield for Vitara
    hood insulation is to prevent the heat from the engine from deteriorating (fading & cracking) your hood's paint job.
    nope iba yung nakita ko
    Talagang parang house roof insulating material
    pero mas manipis
    pero mukhang mas ok yung nasa link
    Mar 2003
    DIY lang yung hood insulation using yung roof insulating material. Ganun ginawa nung barkada ko auto niya. Rugby gamit niya. Katagalan natutuklap din pero hinahabol na lang niya ng pandikit.
hood insulaton
