Results 1 to 10 of 18
August 19th, 2004 09:36 AM #1
Mga Sirs,
Ung aking 96 Vtec pag tumatakbo ako below 70km/h maugong yong front left side tires pero pag mga 80km/h na ang takbo ko nawawala. What is the reason kaya?
Thanks sa inyo.
ED
August 19th, 2004 10:42 AM #2
have the wheel bearing checked. i think it needs to be replaced.
or maybe just an alignment problem...
- Mar 2004
- 153
August 19th, 2004 11:04 AM #5I had the same problem before......
its a tire problem.
change the tires... the sound will go away
FrankDrebin GuestAugust 19th, 2004 11:11 AM #6
Kapag Goodyear NCT3 pa yang rubber mo yan na nga ang dahilan.
Basta't Goodyear No Good.
FrankDrebin GuestAugust 19th, 2004 11:46 AM #8
Pwede, ganyan din ang nangyari sa akin. Makapal pa yung NCT3 ko noon kaya hindi ko pinagdudahan ang tires. Umuugong din sa left side. Palit ako ng wheel bearing at repack lahat ng pwede i-repack, wheel alignment. May ugong pa rin. So ipina-balance ko yung gulong. Ayun! Oblong na daw. Mga 60% pa ring thread niya so medyo makapal pa siya pero mga 4 years old na siya nun.
August 19th, 2004 01:47 PM #10
baka nga oblong na yang goma. anong goma yung nakalagay sa kotse ngayon?
Monk-owned R53
