Results 1 to 15 of 15
    Feb 2006
    Biglang umilaw SRS indicator ng Gen1 CRV and doesn't go off when ignition switch is on. Goes off only when ignition turned off. Ano kaya problema? Checked the fuse but seems ok naman. Would the airbags misfire?
    Thanks
    Just to be sure, why not remove the fuse of the airbags for now then bring it to casa for checkup... Baka pumutok pa ng wala sa oras yan.
    Some cars talagang may sakit na ganyan. It could be a faulty connection. Just have the casa check. ;)
    defintely, bring it over to the casa.
    Aug 2005
    either sa wiring yan or the srs airbag mismo. kakatakot yan baka biglang magmisfire, tanggalin mo muna fuse para sure
    Feb 2006
    Thanks sa mga replies. Tinaggal ko na fuse. Will bring it to the casa next week. Baguio based kase kaya the nearest Honda cars is sa Pangasinan pa.
    nagkaganyan din yung gen1 crv namin dati. the casa replaced the actuator yata or harness, forgot na . had to spend around 14K yata or 21K, forgot na rin. tumatanda na :bela:
    Signature
    Jun 2005
    woah! mahal pala nun.... di ba kasama sa warranty yun? di naman wear and tear component yun diba?
    3 yrs lang ang warranty ng crv, since gen1 pa yan, out of warranty na yan.
    Signature
    Jun 2005
    just got me curious bakit nasisira yun... di naman ginagamit. i mean di naman normal wear and tear yun eh.... but then again yung sensors nasisira? pero di ko talaga magets eh... hehehe
    try disconnecting the battery terminal and plug it back baka mareset...
    Nov 2003
    you won't be able to reset it with the battery. if you need to have something like that done on your crv bring it to the shop. i've reset about 4 or 5 srs lights on CRV's na
    you need a diagnostic computer to reset it.
    Jul 2005
    Quote Originally Posted by pomelo
    Thanks
    Airbag clockspring is most likely the culprit. Have it checked at the Casa just to be sure.
    ano na kaya balita with pomelo?
    ung sa escape ko umiilaw kapag nagalaw ung wire connecting sa may ilalim ng front seats..
    ang ginagawa ko.. tatangalin ko tas ibabalik ko ulit.
    ewan ko lang sa crv.. pangit kasi ung pinaglagyan ng sa escape daling magalaw.
Help - SRS indicator doesn't go off
