Results 1 to 10 of 30
August 5th, 2007 08:22 PM #1
Good Day guys
Here's the scenario. i have a '99 Nissan GTS. naka Airbag ang problem ko sira na busina ko, mismo sa loob ng manubela. pinacheck ko sabi CASA lang mkakagawa nun, i inquire sa nissan casa, d nadaw nagagwaw, bili nadaw ng bago worth 9K (lintek busina lang problema ko) kasi daw yung adaptor electronic type daw. d nagagawa pag sira Bago ndaw.
is there a way para gumana busina ko. without costing that much.
please help.
August 6th, 2007 09:09 AM #3
You can try to bypass the horn mechanism inside the steering wheel assembly. External horn button na mounted elsewhere. Parang yung mga nasa ibang PUJ.
Sobra naman yung talyer na yon at kasa. Ang alam ko, you just have to disconnect the battery terminals para di ma-activate yung airbag sensors by accident, so you can safely disassemble yung steering wheel panel. Tapos pa- bypass mo sa auto electrician, gaya nung ginawa sa akin (pero wala akong airbag ha?)
Baka naman horn relay lang problema?
August 6th, 2007 09:51 AM #4
d horn relay eh.
the adaptor itself na ang problema eh.
is there any other way, meron bang parang ganun adaptor same sa nissan airbag adaptor.
- Nov 2006
- 299
August 6th, 2007 10:08 AM #5ingat ka dyan,di basta basta na problema yan kasi palagay ko parang iisa ang connector ng air bag at ng busina at mas maganda maliban sa idisconnect mo yung battery hanapin mo rin yung air bag fuse para sigurado at wait ka ng at least 15 minutes to discharge the stored voltage sa sri system.panigurado lang.ingat ka.
August 6th, 2007 11:25 AM #6
oo nga eh.
busina na, laki na ng gastos.
is there any other way na ibang adaptor kht na manubela iba palit.
someone mentioned na MOMO adaptor, but wala pako nababasa na pwde.
- Nov 2006
- 299
August 6th, 2007 02:19 PM #7kaibigan no offense ha pero parang nakkalito yata ang problema mo.sabihin mo daw kung ano talaga ang specific na detalye tungkol sa problema at ang cause ng problema.sabi mo kasi di na gumagana,as in totally ba na walang sound,o meron ng konti?kailan at anong nangyari bago ito di na gumana?
August 6th, 2007 03:47 PM #8
sorry pre.. kung magulo.
ganto yun, nawala ang busina ko as in d na tumutunog, then pinacheck ko saking suking talyer and findings nila sira ang electronic adaptor(the one controlling the busina and yung trigger ng airbag). ngyn d nadaw narerepair yun bili agad sa CASA. which is worth 6K, yung adaptor lang yun. ganun k mahal.
tanong ko, meron bang paraan like
1.) may experience at nalusutan
2.) gumagawa ng sirang adaptor
3.) surplus na mura. kasi buong steering column agad.
August 7th, 2007 10:54 AM #9
madami naman yata nissan casa dito para ma canvass mo yung part. ang ibang term dito ay airbag clock spring nadito yung mga wires para sa airbag, horn, cruise control (if equipped) or radio control (if equipped).some veh manufacturers ay may warranty or recall (not sure about the nissan), maybe you can search sa internet malay mo baka warranty pa yan.
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 8th, 2007 08:54 AM #10yup, putol na siguro yung band sa loob...
palitan mo nalang manibela mo with one na walang airbag. then tangal nalang ng ilaw sa dash. hehe!
At RC Security Group, we provide trusted and affordable security patrols Brisbane to keep your...
Transcend Drivepro 520 - In and Out Security ...
