Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
    #21
    Quote Originally Posted by miluku View Post
    Hello. Question lang po. Ako din, city 04 at, lately pag inoff ko sya tapos start ko after 10mins or less than that, parang ayaw magstart, naka 2tries ako nung isang araw. pero pag matagal na sya d gamit (let's say after several hours) ok naman..isang click lang nagsstart na.. basta..pag mainit pa siguro..medyo sablay magstart..bakit po kaya? thank you po.. =)
    sa civic ganyan din, pagmainit pa makina dahil bagong "off" palang then try mong strat nagreredondo pero ayaw tumuloy, pasira na ang ECT sensor nag palit ako after that one click na lang ang starting, kahit mainit ang makina.
    Apr 2005
    #22
    TRY a different gas company, when I switched to Shell unleaded start agad.
    Apr 2011
    #23
    Pa overhaul mo na sir. Ganyan din Galant VR V6 1995 ko dati. Hard starting pag umaga. Basa 1 plug lagi. Turns out, matigas na yung mga valve seal tapos dumikit na yung oil ring sa mga piston. Pinababa ko yung makina at pinapalitan lahat. After the overhaul, 1 click nalang lagi yung start nya. Ayaw ko na isipin how much it cost me to have it done though.
    By the way, may usok po ba yung andar ng car ninyo? Or do you notice na may nag ccake na stuff dun sa tip ng tailpipe? Those are indicators of burned oil.
    Since you say na 1979 model yung car nyo, and assuming hindi pa nabukas yung engine nyan, it's highly possible na loose compression na yung engine ninyo. Have it checked right away and gaganda ulit andar nyan...
Help Needed: Hard Starting
