mga sir nilinis ko po kasi yung winshield washer motor kasi matagal ng hindi gumagana, pagkatapos kong linisan gumana na siya pero ang problema mga sir nagiinit siya, normal lang po ba na uminit yung windshield washer motor tsaka nilalagyan din poba ng oil ung motor?
TIA
Windshield washer motors usually emit mild warm temperatures, and varies on how long they are used. If it is used continually, say 1 min, then the temp will surely rise, but these temp should not reach burning temperatures. If your motor immediately reaches high temps even on a short period, then there is something wrong. Check for the following: 1. Restricted rotor speed due to rusty bushings, 2. Damaged coil, 3. Defective water pump which is hard to rotate. You may apply oil or a little amount of grease to the motor bushing.
