Results 1 to 3 of 3
June 14th, 2013 10:22 PM #1
mga sir nilinis ko po kasi yung winshield washer motor kasi matagal ng hindi gumagana, pagkatapos kong linisan gumana na siya pero ang problema mga sir nagiinit siya, normal lang po ba na uminit yung windshield washer motor tsaka nilalagyan din poba ng oil ung motor?
TIA
- Nov 2008
- 641
June 15th, 2013 06:20 PM #2Sir sotel,
Windshield washer motors usually emit mild warm temperatures, and varies on how long they are used. If it is used continually, say 1 min, then the temp will surely rise, but these temp should not reach burning temperatures. If your motor immediately reaches high temps even on a short period, then there is something wrong. Check for the following: 1. Restricted rotor speed due to rusty bushings, 2. Damaged coil, 3. Defective water pump which is hard to rotate. You may apply oil or a little amount of grease to the motor bushing.
- Oct 2009
- 2,271
June 16th, 2013 04:21 PM #3normal lang yan kasi high speed ang winshied motor...saka hindi naman ginagamit ng matagal yan pitik pitik lang kaya hindi naman siya ganun ka risky..
