Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Mar 2007
    Tsikot Tsips!
    My 4 month old altis shakes at 35-40 kph. Before and after that speed, nawawala naman, or hindi ko na napapansin kasi higher na ang frequency. I had it checked at casa and they replaced the engine support (warranty claim), but the problem is still there. Casa had a wrong diagnosis on the problem.
    Any suggestions and probable reason for the wiggling, vibration?
    Thanks in advance,
    50 Caliber
    Dec 2003
    sayo rin ba ung altis na may problema dati? forgot wat problem pero napost ata dito un..
    sorry no idea pero taka lang ako since bagong bago pa yan..
    eto ba yung kalampag something???
    Jul 2003
    Madami ang puedeng panggalingan ang vibration.
    1) unbalanced pressure plate and clutch assembly
    2) CV joints and axle
    3) Shocks and suspension bushings
    4) irregular tire wear/ tire irregularities
    5) bent tire rims
    6) unbalanced wheels
    Kailangan dito ay isa-isang pa-check.
    Jun 2007
    Any history of hard bumps? baka na bent ang rims mo
    ganyan dati ang 97 lancer ko dati nung nagpalit ako ng rims nawala ang prob pero check mo muna under warranty naman ang sasakyan mo medyo mahal kasi e
    Mar 2007
    * BB, yessirr, ito unfortunately ang me problema, dati pa.
    Had the wheels checked, though camber alignment wasn't done yet. Sabi sa akin ng service advisor, ok lang daw yun vibrations, dahil pag nag accelerate, ganun daw talaga. Though di pa ko nakasubok ng ibang altis, di kaya na normal lang sa kanya yun?
    They lifted the car before sa casa and had the wheels turn with the 1st gear engaged, mayroon talaga vibration. Thats when they ruled out that maybe the engine support is the problem.
    Is it ok to leave the car sa casa, and stay there until they fix the problem? Hassle pero gusto ko talaga maayos yung problema, kahit sa probinsya pa ang dealer ko.
    Is there a way para mai pinpoint ko sa kanila ang problema thru third party diagnosis, or get some opinion with other dealers/casa?
    Salamat po sa mga response nyo.
    IMO ipa check mo muna sa labas (not casa), like Servitek, check lang, walang babaklasin or anything, then kung ano nakita nung pina-check mo sa labas, sabihin mo dun sa casa, ipagawa mo under warranty.
    Or, dalhin mo kaya sa ibang casa baka makita nila problema.
    Sorry to hear about your problem with your new Altis.
    Quote Originally Posted by 50 Caliber View Post
    Tsikot Tsips!
    Thanks in advance,
    50 Caliber
    check also your tires, baga oblong na.
    Is your ride M/T or A/T?
    Clutch could also be the cause of this vibration at 40KPH....
    3909:trampoline:
    Aug 2004
    If it's specifically at 40 km/h, I'd rule out clutch for the meantime...
    I'd put my bet on an alignment or rim issue. Have your alignment checked and your tires rebalanced.
    It's not uncommon to get a "lemon" tire, one that will vibrate even if it's not worn completely out. To rule out tires as a cause, rotate them all... Put your front wheels in the back and your rear wheels in front then test drive it. I'm betting that'll cure the vibration.
    The casa replaced your engine support? If it wasn't busted, that was a waste of money... at least, since it's under warranty, it's their money, but still...
Altis body shaking * 35-40 Kph
