Results 1 to 10 of 15
September 24th, 2007 11:44 PM #1
Tsikot Tsips!
My 4 month old altis shakes at 35-40 kph. Before and after that speed, nawawala naman, or hindi ko na napapansin kasi higher na ang frequency. I had it checked at casa and they replaced the engine support (warranty claim), but the problem is still there. Casa had a wrong diagnosis on the problem.
Any suggestions and probable reason for the wiggling, vibration?
Thanks in advance,
50 Caliber
September 24th, 2007 11:50 PM #2
sayo rin ba ung altis na may problema dati? forgot wat problem pero napost ata dito un..
sorry no idea pero taka lang ako since bagong bago pa yan..
- Jul 2003
- 573
September 25th, 2007 12:18 AM #4Madami ang puedeng panggalingan ang vibration.
1) unbalanced pressure plate and clutch assembly
2) CV joints and axle
3) Shocks and suspension bushings
4) irregular tire wear/ tire irregularities
5) bent tire rims
6) unbalanced wheels
Kailangan dito ay isa-isang pa-check.
September 25th, 2007 12:26 AM #5
Any history of hard bumps? baka na bent ang rims mo
ganyan dati ang 97 lancer ko dati nung nagpalit ako ng rims nawala ang prob pero check mo muna under warranty naman ang sasakyan mo medyo mahal kasi e
September 25th, 2007 09:50 AM #6
September 25th, 2007 10:06 AM #7
Is your ride M/T or A/T?
Clutch could also be the cause of this vibration at 40KPH....
3909:trampoline:
September 25th, 2007 11:40 AM #8
If it's specifically at 40 km/h, I'd rule out clutch for the meantime...
I'd put my bet on an alignment or rim issue. Have your alignment checked and your tires rebalanced.
It's not uncommon to get a "lemon" tire, one that will vibrate even if it's not worn completely out. To rule out tires as a cause, rotate them all... Put your front wheels in the back and your rear wheels in front then test drive it. I'm betting that'll cure the vibration.
The casa replaced your engine support? If it wasn't busted, that was a waste of money... at least, since it's under warranty, it's their money, but still...
Tsikot Member Rank 4
- 2,716
September 25th, 2007 12:05 PM #9leave your car at the casa ... let them troubleshoot the problem properly, not just guessing, and tell them you are not getting the car back until the problem is fixed ... and when they tell you that the problem is fixed, drive it with the their mechanics to verify their claim.
September 25th, 2007 12:17 PM #10
ipa-balance mo muna wheels mo. pwede naman ata gawin ito sa casa para sureball
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
