Results 1 to 20 of 20
    Aug 2003
    anong brand and ilang liters ba nag kailangan ng vios 1.3l?
    and ok na ba ang fully synthetic?
    gusto ko sana ay yung value for money yung price kasi every 5,000km naman yung pagpapachange oil ko and I think madalas ako magpapalit dahil 60 km araw-araw ang byahe ko.
    TMO!!! or toyota motor oil!!! dabest
    compared sa mineral... mas mahal ang gagastusin mo kapag nag fully-synthetic ka...
    pero ok rin naman ang mineral oil... basta palit lang lagi every 5K or 3months. may mga SL na rating na rin naman ang mineral oil...
    If that's the case, regular mineral oil will do quite fine (3-4L?). You can opt to use CASA oil or bring in your own.
    If you want added "protection", then you can also look at semi-synth oils from Shell or Castrol (mga P200+/L, half the price of full-synths).
    Quote Originally Posted by vinj
    bring your own? or buy it from them? hehehe.. usually pag ganyan, pagpipilitan nilang sa kanila ka bumili. kasi kikita sila dun e.
    or else sasabihin nilang baka fake un, in my case, ganun ang sinabe saken.
    mga garapal na service advisor talaga.
    last 10k pms ko, may nilagay na "gas additive" para daw malinis ung fuel line. pero huli na ang lahat, nailagay na nila bago ko pa nasabe.
    ung car care kit, hindi ko na din pinalagay.
    Nov 2003
    go for the best oil you can afford. also check the viscosity vs what is recommended by the manufacturer.
    Yup, lumang gimik na yang "fake" oil or di-compatible daw yung oil mo... pag ganyan painumin mo sa kanya. :D
    Based on my experiences dati, i always take the advise of the Service Advisors with a grain of salt.
    Aug 2003
    thanks for all of your responses
    it turned out na medyo mas mahal pa un nagastos ko nung nagdala ko ng sariling oil, di rin naman pala kasi gaanong mataas un toyota motor oils. since i'm planning to have my oil changed every 5k/3mos, malamang sa toyota na lang rin ako kumuha next time.
    thanks again
    u can save money po by using toyota regular motor oil.. only 130 pero liter... but ask nyo muna sa casa.. some casas dont allow customers to bring in their own oil eh... u can get oil sa labas... mga 100-110 pesos po
    and.. dont use oils na ndi nyo pa naririnig ang names.. madami dyan na ndi ok ang quality.. but nabebenta lang dahil sa tieups with dealers.. etc etc
    would it be possible for toyota to be using generic motor oils then branding it as TMO?
    not advisable ang fully synthetic oils sa brand new engines. kailangan at least 5,000 km. na tinakbo ng car bago mo palitan ng fully synthetic oil.
    Any special reason/s po kung bakit "not advisable" ang fully synthetic oils sa brand new Engines? Concerned lang ako kasi at 1k pa lang nag change na ako sa fully synthethic oil. Nasa 5K+ na yung odo ko and I would like to check if there are any bad effects on this on my car. Diesel Engine pala yung car.
    appricate any inputs.
    Thanks.
    Ch0k0y
    Quote Originally Posted by falken
    Jul 2010
    I agree. The cylinders need the regular motor oil for around 5k mileage to ensure better fit with the piston and piston rings....hehehe
    the mechanics told me ok quality nito eh compared to non popular branded synthetics
    Oct 2003
    i saw one time yung oil na ginagamit ng toyota (this was in otis) is mobil 1. magandang brand yun di ba? i saw them loading some stocks kasi eh.
    Quote Originally Posted by zechs
    those are for their fully synthetic offerings. my rav4 is running on mobil1 right now (my casa is toyota shaw-ortigas).
    mobil1 is one of the best (and also expensive) motor oil around.
    btw, I used to buy oil before from chieffy and have it used on my rav4 for my PMS. no problem with those guys at toyota shaw-ortigas.
    Oct 2011
    Quote Originally Posted by zechs View Post
    Mobil 1 FS oil ng Toyota? If that's the case, magandang klaseng oil yan sir. I think Casa is selling Php600+/Li for their FS oil.
    fully synthetic oil gamit ko on 5kms...
    akala ko makakatipid sa labor cost
    pero nung pagdating na ng 10k pms,
    900php ang labor!!!
    holy shiyet! pinalitan lang ang sparks, den brakes, den ung gas additive na ewan.
    kahit ako, kaya ko gawin magisa un e.
    ayoko na sana mag pa service sa casa ng 10k pms ko.
    nakalagay sa booklet, rotate tires sa 10k kms...
    pero ndi naman pinalitan.
    nakaka bwiset ung mga service advisor ko...
    one time, iniwan ko ung rav4, para pacheck ung backdoor rattle.
    then nung pag kuha ko, puro tire black na ung buong plastic interior!
    naglalangis ung buong sasakyan nung pagkuha ko.
    sa susunod na mangyari to, pwede ba ko mag file ng formal complain?
    sorry, ot na...
    Quote Originally Posted by alex manalo View Post
    kung 5k kms naman ay magpapalit ka, ok na mineral.
    Feb 2009
    at 1000 km (621 miles), your engine is still breaking in. there is no need to change the oil at this time nor is there a need to add anything to the engine oil. adding friction modifiers only prolong the break in period and your average fuel economy would still be poor. follow the owner's manual recommendations.
1000km check-up ng vios 1.3, ano oil ipapalagay ko
