Results 1 to 10 of 39
- Oct 2006
- 128
October 5th, 2007 01:35 AM #1it happened to me 3x na, nangyayari yan pag ung balljoint sa ilalim ng gulong ay bumagsak (nagcollapse) so tutukod un sa mag wheels, pag tumukod bakal sa bakal yan, di yan aandar kahit itulok napakahirap itulak, kung ipwepwersa mo paandaarin u will hear a screaching sound, thats ur magwheels getting destroyed kasi kinakayod, then para ka ngang naka handbrake kasi ung gulong na nastuck di aandar at mamamatayan ka ng engine kahit malakas ang revolution ng makina, kasi di nya kaya... usually what u will do is actually do the repair on site... buy a new bushing (ball joint) sa autosupply then replace it ( perhaps with a mechanic)..
with my first experience, what happened was pagbagsak sa humps biglang nagstuck ung gulong di umandar tinry itulak, itinry buhatin ung isang side ng body para umandar to no avail, so na tow to the nearest auto mechanic
with the next experience ganun din, siguro wear and tear kasi rumurupok din un pag di napapalitan, kaya bumigay, dis time tinry ko paandarin kinayod ung gulong, then tinabi ko, then have it replaced with a mechanic na nahanap ko
next experience, nasira uli, this time sa village, i bought a replacement sa auto supply brought a mechanic, jacked the car and replaced it
thats in a span of several years...
hope this helps
- Nov 2006
- 299
October 5th, 2007 02:25 AM #2para malaman mo kung brake nga talaga ang problema,kailangan mo muna itong ibleed para mairelease mo ang piston ng wheel cylinder pabalik sa kanyang position.
October 5th, 2007 06:54 AM #3
mga magkano kaya gastos for replacement ng ball joint? hindi naman screeching sound ung narinig ko.... parang tok tok sound na naipit... i hope stuck up shoe lang para malinis. isang gulong lang ba talaga di iikot talaga? or both rear tires?
nurse on wheels
- Dec 2006
- 392
October 5th, 2007 07:17 AM #4have the vehicle checked, it's hard to diagnose just like this. in my case, i didn't use the car for several days, with the handbrake up. when i drove it, it felt like the handbrake was still up and i wasn't moving that fast. then i heard something give and the brake pedal went really low (lubog) when i would step on it. i would also hear this weird sound everytime i'd step on the brakes. when i opened up the thing, i saw that the lining of the brake shoe (hope it's the correct term) had peeled off. good thing that was the only problem. had them changed and bled the brakes too, end of problem.
October 5th, 2007 10:57 AM #5
na experience ko na din yan nung lumusong ako sa baha tapos hindi ko nagamit ng 2 days, nung gagamitin ko na ayaw ng umandar kasi nanikit na yung brake. then tawag ako sa friendly neighborhod mechanic. inisa isa yung gulong kung alin ang na stuck. tinanggal, nilinis, ikinabit ayos na alang pinalitan. P300 ang damage.
Engines also work harder, right?
