Results 1 to 10 of 19
- Aug 2003
- 38
January 7th, 2004 11:02 AM #1tsikot peeps, i need your help!
minsan, nagkamali ako ng timpla sa primera (siyempre, namatay yung engine), pag restart ko, ayaw umandar ng oto (lancer 94 glxi). ayaw kumagat eh, pero may sound na "tik..tik..tik.." after a while, i checked the stereo to remove the CD pero walang power (hindi ko na-remove) so we suspected na battery. ginalaw ng kasama ko ang battery terminals, pamaya-maya nag-arm yung alarm at ayun, na-start ko. sabi ng kasama ko loose connection daw. pina-check ko sa battery shop kung ok pa battery and alternator, ok pa naman daw. nilinis yung mga terminals and hinigpitan.
ginarahe ko muna yung oto since sunday na naka-arm yung alarm. pag-check ko this morning, wala yung alarm, hindi ko na naman ma-start yung oto. ano kaya problema?
FrankDrebin Guest
- Aug 2003
- 38
January 7th, 2004 11:29 AM #4frank, ok pa naman daw yunng battery.
ssaloon, di ko pa na-check yung relay, pero ngayon mukhang drained na battery dahil wala nang ilaw yung alarm. ano kaya problema?
FrankDrebin GuestJanuary 7th, 2004 11:56 AM #5
"...may sound na "tik..tik..tik.." after a while..."
Stuck up yung starter?
- Aug 2003
- 38
January 7th, 2004 01:21 PM #7yup pajerokid efi. paano ba i-check ng mahusay kung battery or alternator? before ko igarahe last sunday ok naman. di ko maintindihan bakit nadiskarga within 3 days.
need your help badly guys.
FrankDrebin Guest
- Aug 2003
- 38
January 7th, 2004 01:27 PM #9by the way, pati indicator lights wala--drained ba talaga battery kung ganito?
- Aug 2003
- 38
January 7th, 2004 01:32 PM #10hindi ko alam frank no idea. last month ko lang nabili itong oto. battery kaya ang culprit? nag-iisip ako kung alternator baka kasi kapag pinalitan ko battery eh sirain naman ng alternator. ano ba ang solenoid?
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
