Results 1 to 10 of 12
Unregistered user
- Jun 2003
- 1,121
November 30th, 2004 07:10 PM #1it just happend yesterday evening
when i turn on the my pick up's a/c foul odor emits from air vents
more noticeable on the on two vents near right window and left window
i tried spraying lysol directly into the a/c vents (no luck) nothing happened.
what seems to be the problem...
last thing i did yesterday afternoon was have it engine detailed at big berts :P (nice job )
another question fan belts are squeaking when tachometer hits 3000rpm
what should i do .....
thanks
:confused:
Unregistered user
- Jun 2003
- 1,121
November 30th, 2004 10:34 PM #3
Cooling coil or others call it evaporator leak. Kelangan na palitan yan ng bago.
Yung foul smell na naamoy mo is actually freon.
Unregistered user
- Jun 2003
- 1,121
Unregistered user
- Jun 2003
- 1,121
December 1st, 2004 01:39 PM #8Originally posted by Sheep
thanks
:confused:
SannyC3
Unregistered user
- Jun 2003
- 1,121
December 3rd, 2004 06:37 PM #9turned out to be a heater core problem.
not related with the car aircon...
para syang maliit na radiator sa loob ng car katabi ng evaporator responsible for the heater to function damn baklas yung buong ilalim ng dash ko ngayon, wala pa rin mabili.....
had one fabricated out of copper sa evangelista had to shell out 4k plus
December 3rd, 2004 07:30 PM #10
Baka hindi mo ginagamit ang heater mo. You need to use it once in a while. Engine coolant ang laman ng heater core. :D
VinFast VF 3
