Results 1 to 6 of 6
- Jul 2007
- 5
August 13th, 2007 06:18 PM #1Saan ako pwede makabili nang Manifold absolute power (MAP) sensor para sa Ford lynx ko? .. may mabibili ba ako sa Banawe
Nagloloko engine nang 1999 ford lynx ko. Sabi nang Ford Makati defective na daw MAP sensor nang kotse ko. Problem ko .. sobrang mahal nang MAP sensor .. 12K + VAT + installation fee pa ..
Bago ako gumasta nang pera gusto ko sanang malaman kung may mabibili akong mas mura na MAP sensor .. proprietary item ba ito nang FORD? ..
August 13th, 2007 06:43 PM #2
Try Fordland. 732-1206
Specify that it is a MAP, not a MAF that you need. Typically, prices are about half of what the casa charges.
August 13th, 2007 09:52 PM #3
Astro
Sabihin mo Manifold Absolute Pressure. Pag sabihin mo power baka mas lalo kang mahalan. Mass Air Flow meter is the other term.
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 16th, 2007 08:53 AM #5
Here are the definition of two sensor. Magkaiba po sila ng gamit para sa engine kaya be sure na map sensor ang kailangan nyo.
MAP sensor - Refers to a manifold absolute pressure sensor, a variable resistor used to monitor the difference in pressure between the intake manifold at outside atmosphere.
MAF sensor (mass air flow sensor) - A device used in many fuel injected engines to measure the amount of air entering the engine so the computer can control the air/fuel mixture. Located ahead of the throttle body, the MAF sensor uses a heated wire or filament to measure airflow.
August 16th, 2007 10:51 AM #6
Oh, if we're talking about that kind of MAP, then, yes the Ford Lynx doesn't have one.
Get the service advisor to point out the piece you need. If it's a little black box on the intake tube, that's the MAF.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
