Results 1 to 20 of 20
Threaded View
    Feb 2005
    Hello guys, i have a problem with my car. Its a carby, contact point type car.
    Lately, i experience hard starting when the car has just been parked for half an hour, when it was just turned off or overnight(kahit kelan hard start na). The engine cranks and all, pero ayaw tumuloy ng start. Even apakan mo accelerator to help the engine start, walang kwenta. I know this is not normal, kasi dati one-try lang okay na.
    I also encounter yung parang pumupugak pugak yung oto, even at normal speeds(40kph) or if ihahataw ko.
    Carb newly overhauled by A & M
    Fuel filter good
    Battery good (checked)
    Alternator good (checked 14v on idle, 13.8v acc all on)
    Timing set already
    New contact points/condenser (genuine)
    Plugs cleaned
    Valve clearance adjusted
    Possible problem?
    Timing
    ignition coil
    carb
    fuel pump
    etc..
    please help me, daily driven pa naman ang oto, yari pag tumirik.
Hard starting problem: Help me diagnose my car
