Results 1 to 7 of 7
- Oct 2006
- 30
April 23rd, 2007 11:34 AM #1Hello po mga sir,
Need your help lang po... ano po kaya ang problem ng car ko kc po pg tiniturn on yung ignition, ng reredondo lang po sya, mga 3x po na try bago mg start. pag cold start po sa umaga, ok naman po.. one click lang. Pag ginamit mo lang po sya. Parang kahapon po ngpunta po ako ng Mall then pinark ko lang then nung paalis na ako, nung start ko na yun na. Parang nagiging ganito pag mainit na yung makina. Actually nangyari na po to sakin last week akala ko po battery lang so ngpapalit ako ng brandnew battery. Hindi naman po over use yung car...actually during weekend lang sya nagagamit. Nagwoworry lang po ako kc baka itirik ako or di na umistart.
Ask ko na rin po kung normal lang yung pag umaga walang laman yung water reserve ko... yung radiator meron naman. pero pag ginamit na sya then pag chineck na yung reserve meron na.. is this normal?
Thank you very much po.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 23rd, 2007 12:39 PM #3could be many things from old plugs to faulty starter to a dirty intak manifold.
- May 2006
- 141
April 25th, 2007 08:36 AM #4Sir maperong pareho tayo ng case nun ganyan din pag mainit na hard starting na. pinacheck ko battery nun ok naman then binaba pa nga starter ganun parin..then yun pla ang problem lang may isang ground na kinakalawang na ayun nilinis lang tapos problem..
Try mo check mo yung ground nkakabit s chasis tatlo yan meron sa battery then yung sa engine yun..baka may kalawang na linisin mo..yung sa akin yung sa may battery ang may kalawang.
Baka maka tulong.
Thanks!
April 25th, 2007 05:08 PM #5
research mo lang sir yung cps (crankshaft position sensor) parang me nabasa ako before na hidden recall ito (or check with your dealer). pag hot soak na mataas na resistance nito (or possibly open resistance na)
- Nov 2003
- 3,849
April 25th, 2007 10:03 PM #6t2erns, that problem started only on the 01-05 civics. yung vtec 3.
the 00 is still a vti so hindi dun yung problem nya.
