Results 1 to 10 of 12
- Apr 2012
- 5
September 19th, 2012 12:36 PM #1need your opinion mga sirs... medyo matigas ang clutch pedal ko. sa isang mekaniko ang diagnose po nya ay kelangan na daw po magpalit ng clutch lining.... sa isang mekaniko naman po ay diagnose niya ay papalitan yung clutch slave cylinder kasi daw po maliit ung nakakabit. 13/16 po yung nakakabit ngayon. sabi po ng mekaniko 7/8 daw po dapat. corolla gli 97 po yung unit. ano po ba ang stock na clutch slave cylinder ng auto ko?
thanks po in advance.
- Jul 2003
- 573
September 24th, 2012 04:35 PM #2kadalasan ang problem ay galing sa clutch disc at pressure plate assembly. Sabay pinapalitan kasama na din ang release bearing dahil medyo may kahirapan ang pag baklas at pag kabit ng transmission. Sa ganuon ipara maiwasan ang paulit-ulit na pagbaba ng transmission.
- Apr 2012
- 5
- Jul 2003
- 573
September 30th, 2012 07:04 PM #4di ko alam kung magkano gastos, pero puede kang mag tanong the parts price by telephone sa mga auto supply.
- Nov 2009
- 1,756
September 30th, 2012 10:08 PM #5
- Jul 2011
- 262
November 11th, 2012 10:39 PM #6applicable po kaya ito sa kia pregio..tigas din ng clutch ko..minsan kapag nababad pa yung paa sa pedal eh hindi ma-shift sa ibang gear. hirap ikambyo..parang stock up. TIA
- 48
December 12th, 2012 01:44 PM #7sir firefish,
suggestion ko is to do the easier and cheaper fix first. yung clutch slave cylinder costs around 450pesos and around 200pesos for labor. kapag sa clutch plate ka kasi agad nagpunta, mahina na ang almost 4000pesos on parts alone, plus another 1000pesos for labor po.
sir gtamp,
from your description its again best (cheaper) to fix/replace your clutch slave cylinder first. kaya humihirap ikambyo kapag matagal na nakaapak kasi may internal leak na ang one of the actuators (primary or secondary actuators... assuming hydraulically operated ang clutch system mo po).
hth
January 7th, 2013 12:39 PM #8
changing to a larger slave cylinder may soften your clutch pedal but the stroke (distance) the slave piston travels is decreased which may affect clutch lining engagement (will not fully engage). stay stock. assuming no problem in the hydraulic circuit, check first if there are no binding in the mechanical linkages (pedal, throw out fork, etc). if all else fails, it's usually the pressure springs in the pressure plate assembly. nagpalit ka ba ng pressure plate before?
para klaro lang, matigas lang ba talaga ang clutch pedal pero gears will engage smoothly? kung may grinding sound, the hydraulic circuit is ingesting air preventing full travel of the pistons (assuming no transmission problems).
- Jan 2013
- 143
April 3rd, 2013 04:29 PM #9ganito rin nangyari dun sa lancer ko dati, kala ko masisira yung transmission,
Solution: pinalitan lang ng tito ko yung clutch cable, parang bago na uli yung apak sa clutch.
April 3rd, 2013 04:33 PM #10
how will i know if my clutch need to be replaced? are there any indications?
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
