Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jul 2011
    pa tulong naman, tried to spray yun switch ng contact cleaner pero ayaw parin mawala ilaw kahit naka baba na ang hand break.
    also squeak sa clutch pedal, what to use wd40 or silicon oil?
    Aug 2004
    Quote Originally Posted by alx View Post
    Did you check to see that your brake fluid level is okay? The light often serves multiple purposes... not just as a handbrake light.
    Use grease. WD40 loosens parts quickly, but it is not long term lubricant...
    maybe the switch has to be replaced because it is already defective beyond spraying.. it's not expensive.
    but try adjusting first, if there is provision for adjustment.
    silicone lasts longer than WD40. but good old grease lasts the longest. mahirap lang i-apply..
    Jan 2014
    TS anong car yan?
    I experienced that with the CR-V
    Jul 2011
    thanks for the reply.
    check my brake fluid may laman naman. maybe need replacement na yung switch..
    will try grease to lubricate the clutch springs etc..
    revo ang car ko sir
    if you're going to grease the clutch springs, i suggest you wipe them off lightly after, so's to avoid falling-grease-on-pants/shoes syndrome..
    Jul 2010
    Try to check your brake pads/drum too.
    Jan 2014
    pwede ding sa electricals yan pa check mo sa electrician
    Jul 2011
    sir, already found out whats wrong..
    apparently the fluid is not enough to keep the sensor floating inside the brake fluid cap.
    thanks!
    Mar 2004
    ^^^ You were already advised to check the brake fluid level.
hand break light wont go away
