Results 1 to 14 of 14
    Guys, I need help. Just wanna know kung aling ang possible na may sira. I haven't gone to a real shop for this pero I want to know prior nga kung alin ang may sira. When turning left or right , may naririnig akong kumakalampag sa harap. Is it my rack-end / tie rod + bushings ang may problem??? Pagka staight/patag naman daan e smooth sailing naman. Thank you very much for your replies (in-advance).
    :P :P :P
    My theory: Either CV joint or front wheel bearings.
    Dec 2002
    ganyan din ang nangyayari sa akin. kaso pag nag full left turn lang ang kabig ko sa manibela. and ang cause ng ingay ay yung gulong sa sumasayad sa tapaludo.
    Mar 2003
    i think tama si pajerokid either CV joint yan or front wheel bearings..but i think front wheel bearings yan eh kse sa auto ng kaibigan ko ganun din eh wenever he turns may grumbling sound din..then pina check niya..yun wheel bearings daw..
    Mar 2003
    kung may crackling sound kahit derecho lang ang takbo mo, pwedeng wheel bearings. kung may crackling kapag lumiliko ka lang, cv joint. hth
    kung front wheel bearing baka meron ka maramdaman na konting wiggle, check mo din yung tapalodo mo baka meron sumasayad pag liko mo.
    Mar 2005
    good afternoon, i have my problem similar to this posted already here in tsikot. in fact, i have my revo vx200 checked and drive tested at toyota alabang..the assigned mechanic who drove it, also heard the sound, esp when turning left side way... he mentioned the wheel bearing as possible cause, up to now, ganito pa rin yung situation ng revo ko..My question is how much does it cost fixing this wheel bearing or ng CV joints? hope to hear from you ...
    first swerte ka kasi walang cv joint yang revo, rear wheel drive yan kasi. ang may cv joint e front wheel drive o 4wd. wheel bearings yan
    Feb 2005
    Quote Originally Posted by BongersVX200
    You can check if it is your CV joints. try to look under your car and see if the rubber boots are still good (walang punit). Kung punit na yan, have it repaired or replaced by your mechanic. Repacking it shouldn't cost a lot.
    wala nga CV joint ang RWD hehehe.
    kulet din nya no ehehehe!
    Feb 2005
    Quote Originally Posted by yebo
    Hahaha! Sorry di ko napansin revo pala yung ride.
    Bongers ... Nga naman, basta RWD walang CV Joint. Hehehe.
    unless HICAS 4WSteering :D
    Apr 2005
    mga sir, di kya steering joint?
grumbling sound when turning
