Results 1 to 20 of 25
    Feb 2006
    Mga sirs. Need your advise and inputs.
    Car is a gen1 CRV. Whenever i make a full turn (either to the right or left), there's this "GRRRRRR" sound from under and parang may vibration. Well, this happens only on full turn. Pag balik ng steering wheel to straight position, nawawala. So this is what we did. Baklas ng buong propeller shaft. Checked the crossjoints and may konting alog pero hindi naman grabe. We tried doing a test drive without the propeller shaft and nawala yung GRRRRR sound and vibration. Pagbalik ng propeller shaft, balik din ang GRRRR sound and vibration. Could it be the crossjoints? -- just want to be sure before replacing. Or is it the differential? Or is it the 4WD engaging during full turns? Or what is it kaya? Help naman mga gurus or any other Gen1 CRV owners who have experienced this and had fixed the problem.
    TIA.
    iba ba yung cross joint sa velocity joint?
    Nov 2003
    replace the differential fluid sa likod. sure tangal yung tunog nyan. use high quality atf for that. either redline or motul should do the trick.
    Aug 2006
    Quote Originally Posted by speedyfix View Post
    Gear oil should be used in Diffential,But i dunno in the philippines,Baka iba standard dyan.lol
    Yun rin pala siguro problema ng Gen1 namin dati. Si Honda (casa) naman, hindi nagsasabi na kailangan palitan na ng differential fluid noon.
    Feb 2006
    Ok. Thanks for the inputs. Will try having the atf replaced sa honda pag nagkaroon ng free time..... (Baguio kase location ko and the nearest casa is Pangasinan pa). Thanks again
    Nov 2003
    kaya siguro ng shops sa baguio yan... it's just atf naman and a simple drain refill.
    Aug 2006
    Quote Originally Posted by pomelo View Post
    TIA.
    Where is the noise coming from?
    Front-power steering component(i.e. check fluid,pump, rack and pinion)
    rear- differential.
    Nov 2003
    ronald_m my question is, do you know anything about crv's? the 1st gen in particular?
    my guess is hindi kasi if you checked the differential housing on it you would see a big sign (put there by honda) that you should only use atf in the rear differential.
    this is not a difference in standards na... we're just talking about putting the correct fluid.
    isip isip sana muna bago ka magpost
    Aug 2006
    Yes i do. Sorry ha walang sign yung crv dito na you should use atf in rear pumppkin.
    Aug 2006
    That's the good thing about internet you don't have to think just type type type.lol
    speedyfix...
    for the Rav4 4wd... may kailangan bang palitan na differential fluid?
    buset na Toyota manual yan... walang nakalagay ng maintenance sked.
    Nov 2003
    buti nalang pala nasabi ko sayo or else you would have put the wrong fluid in the car and masira mo pa.
    yan ang mahirap... all you do is post and post and don't think that someone may actually think you know what you're saying and follow your advice. if they did you would probably ruin the car even more. geezzz....
    mazdamazda yeah, pwede every 40-60k kms palitan yun
GRRR sound/vibration on full turn - CRV
