Results 1 to 13 of 13
    Oct 2005
    any advise what do this mean?
    thanks
    Jun 2003
    hmmm that you need to thermal wrap your headers if you are using such or put better insulation underneeath your hood to prevent premature paint wear and cracking
    Oct 2005
    what's your ride sir?
    Jun 2003
    Quote Originally Posted by umzzzzz
    kuliglig daw ata
    May 2005
    Quote Originally Posted by Sheep
    kuliglig daw ata
    sorry..what's a kuliglig?
    kuliglig! sheep, you're mean!
    baka may oil leak sa valve cover gasket tapos tumutulo sa exhaust manifold. or leaking exhaust manifold gasket.
    Aug 2004
    Yup.... probably oil leaking onto the hot manifold. Might be a very slight gasket leak... Likely, after 10-15 minutes, the oil becomes thin enough to pass through the space and spurt onto the exhaust.
    Best check your oil level and look for signs of stains on the engine cover, head, block, etcetera...
    Sep 2005
    OT: Kuliglig = Mechanical Carabao
    Aug 2005
    try mo lagyan yung exaust manifold ng langis kung ganun ang usok possible ay may leak yan.
    Aug 2003
    maling oil xx/yy weight kaya ang nagamit?
    Nov 2003
    it's not the wrong viscosity... it's just leaking. have it fixed, then clean the engine and it should be ok na.
    Aug 2005
    maybe may na drop na langis doon sa exaust pipes.. engine wash muna
    Oct 2005
    Quote Originally Posted by finchy18
    THANKS for all the Help !
Gray smoke sa hood kapag mga 2o minutes ka ng nag d drive?
