Results 1 to 8 of 8
- May 2005
- 16
September 12th, 2006 04:14 PM #1Ma nga sirs, inquire ko lang po kung pwedeng baliktarin ang liner ng 4D56 gaya ng ginagawa sa ibang diesel engines. Thanks.
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 13th, 2006 12:58 PM #3
pede, pero why do it? would you like to go though the process of engine rebuild again when it fails again?
- 10,620
September 13th, 2006 01:08 PM #5
as speedy and afrasay said, i would not recommend also sir.
as much as possible, avoid processes like that. since it is already opened and due for change, change it. labor is quite expensive for a general overhaul. if it fails in a few months, gastos ka nanaman.
if it is possible to bring it back to standard specs without using a liner, better. if not, go for a new liner instead.
- May 2005
- 16
September 18th, 2006 10:47 AM #6Gentlemen where can I get original piston liner aside from El Dorado and how much is the labor cost of general overhaul?
September 18th, 2006 06:04 PM #7
search kayo sa directory sir mga geniune parts ng mitshubishi.
just to give you a few:
atco sa pasay din daw
bbw sa banawe beside jetcar
coltline sa banawe near ha yuan
bestcolt sa banawe fronting coltline
motorix sa banawe malapit din sa ha yuan
- Dec 2013
- 528
December 18th, 2013 12:18 AM #8No need for genuine parts, repack lang naman yan sa boxes ng mitsubishi and etc...
Banaweonline,
yes your right on Atco Pasay, BBW, and Bescolt.
But I would refer him to THK auto supply and Share Auto supply. Trusted retail shop sila sa Banawe. If your gonna buy piston rings, buy RIK piston rings as they are Original Equipment manufacturers of Major Car Makers of Japan.
I got my information from my friend who supplies brand new spare parts to auto supply retailers in the Philippines.
Here is the website proving RIK is the preferred piston ring of Japan Automakers:
Earthquake puts brakes on auto production in Japan - USATODAY.com
Here's the suspect. I replaced the oil sending unit over the weekend. I hope this sopbes my oil...
Oil leak
