Results 1 to 8 of 8
    May 2005
    Ma nga sirs, inquire ko lang po kung pwedeng baliktarin ang liner ng 4D56 gaya ng ginagawa sa ibang diesel engines. Thanks.
    Nov 2003
    i wouldn't. mura lang naman sila right so bili ka nalang ng bago.
    pede, pero why do it? would you like to go though the process of engine rebuild again when it fails again?
    yup...hassle lang...
    Sep 2005
    as speedy and afrasay said, i would not recommend also sir.
    as much as possible, avoid processes like that. since it is already opened and due for change, change it. labor is quite expensive for a general overhaul. if it fails in a few months, gastos ka nanaman.
    if it is possible to bring it back to standard specs without using a liner, better. if not, go for a new liner instead.
    May 2005
    Gentlemen where can I get original piston liner aside from El Dorado and how much is the labor cost of general overhaul?
    Sep 2005
    search kayo sa directory sir mga geniune parts ng mitshubishi.
    just to give you a few:
    atco sa pasay din daw
    bbw sa banawe beside jetcar
    coltline sa banawe near ha yuan
    bestcolt sa banawe fronting coltline
    motorix sa banawe malapit din sa ha yuan
4D56 Piston Liner
