Results 1 to 6 of 6
    Oct 2008
    for those na hindi power windows,
    any tips on how to remove the window knobs? minsan kasi parang ma pwersa pag tinatangal yong wire clip that holds the knob to the door. minsan naman tumatalsik yong wire and ang hirap hanapin.
    also kng me tip din kyo kng pano madali ibalik yong knob
    Jan 2009
    [ame="http://www.youtube.com/watch?v=AwsvicUZ9s4"]YouTube- Auto Repair : How to Remove Window Cranks on Cars[/ame]
    With practice, a flat screwdriver is all you need to remove the clip. To re-install, you just pop it in.
    Feb 2009
    try using thin rags slid from the crank handle side while holding the two ends of the rag stretched. the rag even holds the clip from flying
    Oct 2008
    when you say flat screwdriver, i insert in the crank/clip and then twist until the knob comes out? di kya mabali?
    Jan 2009
    Quote Originally Posted by african888 View Post
    No. Use it to push the clip out of its slot. Cup your other hand around the other side of the crank to catch the clip and prevent it from getting lost.
    Oct 2008
    thanks for the replies
Removing window knobs
