Results 1 to 20 of 21
    Apr 2005
    Mga sir need your opinion at suggestion... Yung pinsan ko kasi nag text sa akin " bigla na lang daw pumupugak yung CRV... any suggestion kung ano magandang gawin? nasa malayong lugar kasi sya at ng hihingi ng advice what to do..
    thank in advance
    any other symptoms?
    smoke could be an indication na oil/water/coolant/a mix of any of the three could be entering the combustion process. has he been seeing any leaks around the engine block itself?
    Dec 2002
    dirty spark plugs or even a dirty air cleaner or even a clogged fuel filter when was the last check up and mileage
    Apr 2005
    Quote Originally Posted by nugundam93 View Post
    any other symptoms?
    sabihin ko to visual check his car...
    Quote Originally Posted by johnart View Post
    50k last PMS which includes change spark plugs, his running 52k right now... sabihin ko linisin na din spark plugs at air filter...
    Jan 2004
    linisin? bili na nang bagong spark plug at air filter.
    Sep 2006
    Hard to diagnose this on the internet.you can also check the maf sensor. How was the idle?
    Jan 2004
    agree with you m_ron.
    MAF sensor... hmmm. nagkakaproblema lang dun kapag nagmodify na nang Air Filter. sa LXi namin, ganun e. kala ko ECU na ang problema- yun pala, fouled-up throttle body.
    Apr 2005
    Quote Originally Posted by ian_rex View Post
    patay... naka modify nga yung air filter nya... knn
    Apr 2005
    sir nasa malayong lugar saya kasi ngayun.. bundok... hehehe linis muna pag dating sa city tsaka palit...
    Quote Originally Posted by m_ron View Post
    text ko muna sir... post ko uli kung ano observation nya...
    check your fuel, baka nakargahan na diesel yan. D4D ba makina ng CRV? :p
Gen 1 CRV 01 model pumupugak
