Results 1 to 9 of 9
June 28th, 2005 08:55 PM #1
hello!tanong ko lang po kung saan ginagamit ang drive na 2 sa AT?D3?Thanks a lot!!!
- Jun 2004
- 185
June 28th, 2005 09:46 PM #2hmm, please check your car's manual.
Generally, drive 2 is gear 2, meaning the engine is using gear one up to gear 2 only. Uses if you need engine brake especially in high angle uphill or downhill. Dont drive higher than 100Kph under this gear.
What vehicle are you referring to?
June 29th, 2005 09:54 AM #3
honda civic 2002 po, if your going uphill like going to baguio should i use d3 or simply d?
June 29th, 2005 10:30 AM #4
You can also use the 1st and 2nd gear to decrease wheelspin especially when getting out of deep snow or slippery mud. Too much wheelspin decreases traction in icy or muddy conditions.
Going to Baguio ok lang sa "drive" position i think. Gamitin mo lang yung gears 1, 2, 3 kung very steep talaga ang road and you have a very heavy load.
June 29th, 2005 02:45 PM #6
Originally Posted by voltes_V
94 Corona po.
tnx.
June 30th, 2005 06:02 AM #7
Originally Posted by bogart
Kung medyo curvy naman ang daan like in baguio, ok pa rin naman sa "drive" position basta just let go of the gas pedal and give slight taps on the brakes para magdownshift ang engine when doing those scary turns.
June 30th, 2005 08:35 AM #8
I think pag nasa 2, based on honda autobox, naka stuck siya sa 2, as in mag start siya to roll from a stop position on gear 2.( that is to prevent wheelspin, kung slippery ang condiotion. e.g. icy, muddy.)
pag pababa kung gusto mo mag engine brake, either you switch o/d OFF, or kung may d3, use d3.
June 30th, 2005 10:00 AM #9
Originally Posted by Rediesel
Believe it or not,the V manual also says you can do upshifting and downshifting through 1,2 and D like a manual transmission without a clutch pedal.
If you shift into first position when the vehicle speed is above 50kph the transmission shifts into 2nd gear first to avoid sudden engine braking. (this is still based on CRV book manual).
